diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Help me design pre-amp PS (http://www.diyaudio.com/forums/tubes-valves/44624-help-design-pre-amp-ps.html)
hardcore 2nd November 2004 02:28 AM
Been trying to get rid of hum in my pre-amp (6sn7 transcoupled to a tango np126)
I have on hand two chokes from Hammond, a 20H and 12H, and Black Gate wkz 100uf+100uf 500v. I tried LCLC (20H, 100uf, 12H, 100uf) and the hum is terrible.
I tried CLCLCR (1 uf, 20H, 100uf, 12H, 100uf, dropping resistor of 20k to reach 260V), hum was not too bad but still heard from listening position
Any suggestions on how to improve my filtration? Been thinking of doing CLCLC (10uf, 20H, 47uf, 12H, 47uf) then split into two RCR (1k, 100uf, drop R of 20K)
Thanks in advance
Geek 2nd November 2004 07:12 AM
Re: Help me design pre-amp PS
Try just 10uF--20H--100uF
mcs 2nd November 2004 02:28 PM
With all those chokes and big caps, I very much doubt that power supply ripple is your problem.
Have you tried DC on the tube heaters?
Have you tried moving the power supply transformer and chokes far away from the output transformer?
Have you tried shielding the amp/tube (if it isn't already)?
Best regards,
Mikkel C. Simonsen
resident 2nd November 2004 03:42 PM
I agree.
Your hum problems may be from other porpuses.I have some humm problems with my amp.Notice that my ripple on filtering is tooooo small.But hummmmmm.
Try to put away the power tranny from the circuit.And be careful with the position of chokes,interstage tranny and power tranny.Keep the safely 90 degrees placement at each other.
Sch3mat1c 2nd November 2004 07:58 PM
10uF, 10H (2H would do it), 100uF. CLC. Ground the first stage properly and bias heaters with a hum balance control.
Tim
yagoolar 2nd November 2004 09:17 PM
I'd rather check earthing/grounding and heater current cables. Simply - check cabling. You can find good papers on earthing/grounding.
Enzo 3rd November 2004 12:46 AM
And make sure the ground returns for the gain stages are not sharing copper or chassis with the power supply or other circuits. The star ground approach.
Isolate the problem. is the hum 60Hz or 120Hz? Ripple will be 120Hz - assuming full wave rectification. 60Hz is hum picked up from the tranny, the heaters, or poor shielding.
Blue 10th November 2004 06:32 AM
As Resident says orientate the iron work to prevent magnetic coupling, and as Enzo says in his US centric way 120Hz or 60Hz which I understand also makes sense in the Philippines, if ripple is the problem, but I doubt it is with the size of chokes, you could resonate them with parallel capacitors but make sure they are well rated as the current in them could be high.
Resources saved on this page: MySQL 18.75%
