psu design problem
psu design problem
Old 2nd November 2004, 12:49 AM   #1
then_dude is offline then_dude  Belgium
Default psu design problem
hello everybody,
i wanna build an amp : an push pull el84; that is also driven by an el84
the problem is that i have already material lying around.
i have a power supply that if you put 220 on it (i live in europe) you get 140 volt out of it. (0.2amp)
the orginal design was an push pull el84 driven by 3 ecc83, and also 2*ecc83 for the phono stage.
i will have to put an extra trannie for the heaters.
but now the real problem, i 'm gonna go solid state psu, because it's a first project, and also wanna keep the cost low. In the original there is a voltage doubler (the one you get with the psu designer, hahaha, it uses 100uf) , so it puts out 280 volt, that's allright, (i has to be 300 but i don't think i can get that, or am i wrong, still with 280 i gotta work also).
but what after that voltage doubler ? a snubber circuit, and an CRC or CLC circuit and how to implement ?
i find psu schemes the hardest of an amplifier, that's why i call the help of some guys. i have already simulated with the psu designer, but don't feel to sure about it. so any help is welcome
thanx guys
Old 2nd November 2004, 09:19 PM   #2
resident is offline resident
Account Disabled
Why don't you feel so sure with PSUD2.It's a cool program and works.
Old 2nd November 2004, 09:24 PM   #3
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar psu design problem
You should not be skeptical. I always use it and it *is* accurate.
Old 2nd November 2004, 09:51 PM   #4
yagoolar's Avatar
Hi then_dude,
If I were you, I would go something like that (see attached file). This sim was quick and I don't know much about your PP setup, voltages and so on. I assumed 0.1 A per channel / one psu. However with 1 xformer per channel this does not give you much room for output power and might be insufficient.
(PSUD2, accuracy=high, f=50Hz, Ui=240V, offload Vo=140V)
Old 3rd November 2004, 03:23 AM   #5
jackinnj is offline jackinnj  United States
jackinnj's Avatar
psu design problem
Play around with the transformer -- if you have the nerve you can use a spare filament transformer to place 12.6VAC onthe 6.3VAC winding -- this will double the voltage on the HV secondary (of course, you disconnect the original primary connections );!
a doubler works fine for tube devices -- very suitable for regulation, the displayed image is a regulator with an LM317 regulator which has its adjust pin lifted by a zener string (courtesy of National Semiconductor) Click the image to open in full size.
psu design problemHide this!Advertise here!
Crossover Design Problem lscangus Multi-Way 1 25th November 2005 06:07 AM
PCB Design problem.. Pls advice xitronics Everything Else 5 29th October 2005 06:19 PM
Ongoing bass cab design problem TheoM Subwoofers 15 8th September 2004 05:24 AM
CFP output design problem Duo Solid State 7 19th January 2004 11:38 PM
subwoofer design problem pkgum Subwoofers 90 30th December 2001 01:12 AM
Copyright ©1999-2017 diyAudio
