el84 amp - diyAudio
Old 28th October 2004, 01:11 PM   #1
Default el84 amp
I want to build a new amp...I've bought four el84 but I'm not sure which is the best way to use them. I need 7/10W so the I think that the options could be:
1) sep, pentode connection with local negative feedback
2) push pull, maybe ultraliner connection.
For push pull design I like solution like this:
http://www.meta-gizmo.com/Tri/interstage.html
What's about phase splitting by using an interstage transformer ? I think this could be an interesting solution, perhaps better than pse pentode connection
Thankyou in advance
Mark
Old 28th October 2004, 01:20 PM   #2
SY's Avatar
Using an IT can work, but is (IMO) unneccessarily expensive and removes many design options. The nice thing about EL84s is that they don't require much drive- difficult tubes are a better argument for ITs.
If it were me, I'd build a simpler, more classic design. Have you seen the Bevois Valley amp in Morgan Jones's book?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 28th October 2004, 01:32 PM   #3
diyAudio Moderator Emeritus
Bas Horneman's Avatar
If it where me...I would build http://www.meta-gizmo.com/Tri/interstage.html as well..
can't get any simpler than that.. and to me it IS a classic design.
It sure is a little more expensive...but what is 200$ for something that provides you with years and years of problem free amplification......and the phase splitting does not suffer through time like I suppose a tube based phase splitter does. Plus I happen to believe that adding feedback is like castrating your amp. (Term stolen from the Positive Feedback review of the sixpacs amps...http://www.positive-feedback.com/Issue6/sixpac.htm).
The Bevois valley apparently sounds quite good But is actually quite complex and therefore less suited as a first time build IMO.
Bas
Old 28th October 2004, 10:31 PM   #4
mcs is offline mcs  Denmark
This simple amp works well: http://stiftsbogtrykkeriet.dk/~mcs/EL84_Amp.html
It would be quite easy and cheap to make, if you want to try something simple first.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 30th October 2004, 07:48 AM   #5
audiousername's Avatar
You could use the "Simple EL84" design from www.diyparadise.com (the site is down - bandwidth exceeded). From memory... it's a UL push-pull design with the output serving as phase-splitter since the tubes are mounted in differential.
No idea how it sounds... or how good the phase splitting balance is when done this way
Will check if I saved the schematic
It has been assumed that this is mark_titano's first amp. He hasn't said this
Old 30th October 2004, 08:10 AM   #6
schematic:
Old 30th October 2004, 08:54 AM   #7
frugal-phile(tm)
planet10's Avatar
This little beauty does a good job for almost no money...
http://www.edcorusa.com/transformers...wsm10k-10k.htm
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2004, 08:55 AM   #8
frugal-phile(tm)
planet10's Avatar
That is the same topology as the Morgan Jones amp which SY mentioned. Morgan's amp probably has the detail down better.
dave
Old 30th October 2004, 08:57 AM   #9
frugal-phile(tm)
planet10's Avatar
An elegant amp, but you oonly get half the power.
dave
Old 1st November 2004, 10:38 AM   #10
Thankyou All
It seems that pse design is not a good idea...hehehe
Ok I will try push pull, I never built one ( I'm listening an El34 SE, my second diy amp), I think this could be a good experience.
Maybe I'll try pse design later...
I think that I'll try somethink like this:
http://www.audiodesignguide.com/my/pp3.html
Maybe with better power supply...ccs source for the el84...and battery bias for the input stage.
What's about?
I found two LL1671 (second hand) for 100Euro:
http://www.lundahl.se/pdfs/datash/1671.pdf
what you say? I buy them? I'm not sure that they are ok for small triode like 5842...
Thankyou in advance
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 12:05 PM
EL84 PP Diy. Pls help me!!! BigOx Tubes / Valves 24 11th June 2006 06:09 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
Copyright 1999-2017 diyAudio
