Heating only one half of a double triode - diyAudio
Old 27th October 2004, 03:13 PM   #1
Default Heating only one half of a double triode
Is it OK to let a current source (LM317) heat only one half of a double triode (provided that I only need one single triode in each channel)? Eg. heater current from pin 4 to 9 in the left channel tube and current from 5 to 9 in the right channel tube.
This way I could swap tubes after some time, and get double milage out of the tubes.
Thanx!
Old 27th October 2004, 03:43 PM   #2
Which tube are you using?
Old 27th October 2004, 04:43 PM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Heating only one half of a double triode
Don't see why not. Mind you, I'd simply use both of the valves in the one envelope and not worry about the tiny amount of crosstalk due to the capacitances.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 27th October 2004, 04:54 PM   #4
Thank you EC8010. It still looks a little bit cooler with two tubes, one per channel, than charing one single tube for both channels
RE: kooltubes
It was a general question, however I was thinking about ECC99 or 5687.
Thanx!
Old 27th October 2004, 05:00 PM   #5
Hi Bequerel,
I have tried both the ECC99 and 5687 with AC and DC heaters; I have found that AC sounds best, there is no hum providing that your grounding is good.
Old 27th October 2004, 05:05 PM   #6
Re: kooltubes
Was this in a linestage or as poweramp driver stage?
I will be using it in a linestage with output transformers.
Thanx!
Old 27th October 2004, 05:17 PM   #7
Bequerel,
It's a linestage with output TX
I have tried ECC99 was biased at 18 ma 155 V on the TX input and 18ma without output TX (plate voltage:150V). No hum with AC heaters!
I am still having some difficulties trying to bias the 5687 and the 7044.
However the 5687 and 7044 at 14~15ma are interesting. The 5687 is on the warm side (not my cup of tea); the 7044 is brighter and has more kick than the ECC99....so I am still undecided on which tube to use for the linestage.
Old 27th October 2004, 05:26 PM   #8
"It's a linestage with output TX
I have tried ECC99 was biased at 18 ma 155 V on the TX input and 18ma without output TX (plate voltage:150V). No hum with AC heaters!"
Exactly what I am working on too! Think I will try AC first, since this probably sounds best, too
Thanx!
Old 28th October 2004, 02:40 PM   #9
Send a message via AIM to DigitalJunkie
Or you could parallel both halves. I've heard this can help reduce noise.
Old 28th October 2004, 04:43 PM   #10
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
you could just use similar tubes with only one triode too.
6AV6 = 1/2 12AX7 + 2 diodes
6C4 = 1/2 12AU7
etc..
Seeking Pentode-Triode with a 12AX7 half... jon_010101 Tubes / Valves 12 14th April 2009 11:10 PM
what double triode is less microphonic ? inertial Tubes / Valves 49 19th December 2008 09:21 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
Using one half of double triode cs Tubes / Valves 8 1st March 2006 04:10 PM
a single double triode and two chanel? killerfishes Tubes / Valves 2 14th June 2005 12:16 PM
Copyright 1999-2017 diyAudio
