| diyAudio Sponsor | ||
Hello,
I have tried to build a simple voltage amplifier using one half of 7044 biased at about 18ma (plate resistor 7k5; cathode resistor 300R bypassed with 470µf; supply 290V) Sound is ok but the tube is very microphonic. I have tried 5 other GE 7044, same thing, have I done something wron? I have plugged in a 5687, since it's almost similar as the 7044: less microphonic So what's the best operating point for both tubes RC loaded? Thanks! |
#2 |
i`m running at 170v plate voltage at around 12ma of current
#3 | |
One Seriously Addicted to Audio and Electronics
I don't think you did something wrong. I think the problem is the 7044's since they are all microphonic. The operating point looks o.k., maybe a little high plate/anode dissipation. General rule is about half the Ub on the anode/plate. Greetings, Ray. |
#4 |
Hi Ray,
I have changed the cathode resistor to 470R, which gives me about -7v on the grid and 184V on the plate; current is about 14ma, the microphonics are less and the sound better. What do you mean by "Ub on the anode/plate"? I am still a newbie |
#5 |
I don't think that the problem is the operating point.
Some people like it at approx. 90V @ 10-15mA or 150V @ 10-15mA. Others (like ANJ) use it even lower at 2.5mA only ! Also 15K plate resistor is very popular as a loadline.
Mic |
#6 | |
That means that there should be approx. half the supply-voltage on the plate/anode when idle. The idea is that the anode-voltage can then swing as much up as down. So, in your case, the 184V is a bit on the high side (but will work o.k. with small signals). You can enlarge the anode/plate resistor to achieve about 140...150V voltage drop at 14mA (10k). Take a look at the datasheet graphs if you want to pick a nice operating point. Greetings, Ray. |
#7 |
Hi Ray,
It's done! Thanks. |
#8 |
You're welcome!
If you'd like to know more about tubes: there's a thread here On Line Tube Learning for newbies.... with a lot of info on tubes, since you say you're a newbie Greetings, Ray. |
| Operating point for 6GK5 | AKSA | Tubes / Valves | 6 | 6th October 2008 03:21 PM |
| Driving a 6B4G with a single 5687/7044/E182CC? | G | Tubes / Valves | 2 | 6th May 2007 11:29 PM |
| Best Operating point for a 2A3? | sgerus | Tubes / Valves | 10 | 2nd August 2006 12:31 AM |
| 6GM8 Operating Point | ALBQ | Tubes / Valves | 2 | 23rd November 2004 02:45 AM |
| please advise on operating point of a 5687 | hacknet | Tubes / Valves | 4 | 15th June 2004 04:32 AM |
| Page generated in 0.10767 seconds (78.52% PHP - 21.48% MySQL) with 10 queries |
