Hi
I am using Luxkit A1020 with 4 of Nec 6a-r8 but I tried many time to buy another 6ar8 tube for my reserve.
Unfortunately if my tube is going to die what will I can do with the rest OPT ....remaining thing in my amplifier
What tube can I replace 6ar8 in the future or how can I modify it with Lux OY 14 OPT with 5K
Thanks in advance
Rgds,
Huy
Thanks in advance
Rgds,
Huy
Hi. I have an A-1020 in a good condition. There is no direct replacement for 6RA8. Some of my friends use A2293, but I do not know the details (bias setting, etc.). Also, 6CW5 triode connection may be used, though you have to be careful for the low screen grid voltage specs.
Good luck.
Good luck.
cpu_bach and huytienluu
If you spend time on this site, we need your help, really need a schematic or manual by a1020
Not the right one....
The correct tube is 6R-A8 and is a 15W Japanese Triode only made by NEC, seldom found outside Japan except in sold/exported equipment.
Closest thing would be a Triode wired EL84 and the set adapted to suit, ....
Luxman also had valves made solely for them as well.
Most of these were for the local market though some seem to have "escaped" somehow....
Best way is to try to figure out what the closest possible equivalent could and then adapt the design to that. If at all possible.
Best,
Best,
- Tubes / Valves
- Luxkit A1020 need help!!!
