Luxkit A1020 need help!!!
Old 25th October 2004, 09:11 AM   #1
huytienluu is offline huytienluu  Viet Nam
Send a message via Yahoo to huytienluu
Default Luxkit A1020 need help!!!
Hi
I am using Luxkit A1020 with 4 of Nec 6a-r8 but I tried many time to buy another 6ar8 tube for my reserve.
Unfortunately if my tube is going to die what will I can do with the rest OPT ....remaining thing in my amplifier
What tube can I replace 6ar8 in the future or how can I modify it with Lux OY 14 OPT with 5K
Thanks in advance
Rgds,
Huy
Old 26th October 2004, 02:25 AM   #2
cpu_bach is offline cpu_bach  Japan
Hi. I have an A-1020 in a good condition. There is no direct replacement for 6RA8. Some of my friends use A2293, but I do not know the details (bias setting, etc.). Also, 6CW5 triode connection may be used, though you have to be careful for the low screen grid voltage specs.
Good luck.
Old 26th October 2004, 06:00 AM   #3
Thanks much,
Do you have circuit diagram pls share with me
Thks again,
Huy
Old 27th October 2004, 12:39 AM   #4
Hi, sure I can share the schematic. However, I cannot send you an E-mail through this board due to your preference setting. Give me your E-mail address.
Regards.
Old 28th October 2004, 10:26 AM   #5
Thanks in advance
My email is newlth@hn.vnn.vn
Rgds,
HUY
Old 25th June 2015, 05:39 AM   #6
Traktorist3d is offline Traktorist3d  Russian Federation
cpu_bach and huytienluu
If you spend time on this site, we need your help, really need a schematic or manual by a1020
Old 25th June 2015, 08:15 AM   #7
jazbo8 is offline jazbo8
jazbo8's Avatar
A partial schematic is available on this page.
Old 25th June 2015, 09:52 AM   #8
Thanks, but really need to complete a detailed scheme and better assembly manual
Old 25th June 2015, 10:31 AM   #9
jazbo8's Avatar
Good luck, try writing to Lux.
Old 25th June 2015, 01:03 PM   #10
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Could in the event, re-wire tube sockets and use EL84 which is a similar type tube....
Das Beste Oder Nichts
Luxkit A1020 need help!!!Hide this!Advertise here!
Luxkit Avance Z-504 sismofyt Solid State 8 17th January 2018 02:38 AM
Luxkit A504 repair, long dsprinkle Solid State 34 16th May 2013 01:02 PM
Luxkit A503/Z503 curcuit schematic/build instuction wanted Frank J.Y. Lin Analog Line Level 0 27th December 2006 11:36 AM
