Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 24th October 2004, 01:44 PM   #1
Account Disabled
Default earthing
As I’m laying out the components inside the chassis I was thinking about earthing. I’m building a stereo unit in one chassis. I’m planning of course to use star earthing but ….. to many points. So I’d like to ask if it’s correct to use,
one star earth at L channel
one star earth at R channel
one star earth at the PSU
and then all these at the chassis with the earth points of the electrolytic caps of PSU that are near the phase splitter and the first stage and mains earth, too.
Old 24th October 2004, 04:25 PM   #2
BHD is offline BHD
Send a message via Yahoo to BHD
If you're terminating the ground at several points, it's not star earthing anymore. Star earthing is tough to do and overrated, IMHO. If you're working on a phono preamp it might be worth the extra effort, otherwise it's not a big deal, really.
You may as well just use a ground bus, lots of point to point wired amps use them and work just fine.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 24th October 2004, 06:58 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Nah, it's just referred to as a multi-point star...
Ground the first stage to its respective input. That's the most sensitive stage and as such you want the least ground loop possible. Like, run the ground end of the cathode or whatever to the ground of the RCA jack (or whatever) input.
You could have 5V ground loop around the output before it sounds as loud as 0.1V fed into the input stage... far more important up front!
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
"It's all in your head. So follow your head. Don't bother trying to explain it, because there is no explanation. Likewise, disregard any who try to explain it, because they're most likely way off the mark." - Myself
Old 24th October 2004, 07:58 PM   #4
Account Disabled
Yup!
@ Sch3mat1c
You mean to ground the first stage on the ground input of the RCA and what about the other earth points?
How to ground them all together on chassis?
Old 25th October 2004, 05:02 AM   #5
Default My Earthing Method
Ground at the input socket as suggested above. From there run a bussed earth which follows your schematic. ie input valve grid resistor 0V side is the next connection - then input valve cathode connection etc. all the way to the other end which will be the power supply filter cap 0V and depending on the rectifier scheme possibly a power transformer secondary connection as well.
What you are wanting to achieve is NO power supply etc return currents flowing in the SIGNAL ground wires near the sensitive input. With this scheme the largest currents i.e. the power supply filter cap currents, the output valve return currents etc are confined to the end of the earth bus away from the input.
The above sentence is the critical practical objective for ANY Earthing scheme and the bussed earth method is NOT the ONLY way of achieving it. Its just the easiest to follow in your head and debug if there are problems. Think in terms of "prefered paths" (lowest resistance) for the return currents. Whenever the return path for say (for example) the outout valves cathode currents and the input grid resistor earth connection is the same piece of wire you will have problems. If you avoid this sort of situation you won't have any problems.
Actually if you follow the "follows the schematic" earth philosophy you will find that it doesn't really matter which end of the "earth bus" you actually connect to chassis.
I've had good results with eathing at the power supply end or eathing at the signal input end.
If connecting the "earth bus" to chassis at the power supply end I use a local RF bypass cap (10nF Ceramic) from the input socket ground side to chassis. This puts the input cable shield at the same RF potential as the chassis and stops hash getting into the box.
If connecting the "earth bus" to chassis at the input socket(s) I add a 100 Ohm resistor from the power supply end of the bus to chassis just to stop the whole thing floating if the input wire(s)become disconnected.
There should be one and one ONLY direct connection to the chassis for the signal chain for each channel (ignoring the RF cap or the 100R resistor mentioned above (which are "belts and braces" stuff) and this should be physically as far as possible (the other side of the chassis if possible) from the safety earth (mains earth) chassis connection. This because the leakage from mains filters and the mains transformers should return via the safety earth and not flow through the signal chain earth.
Hope this makes sense to you.
Ian
P.S. For your stereo amp with a sigle common supply I suggest common chassis earth point between the input sockets - separate bussed earths (follow the schematic) for each channel and tie them together BUT not to chassis at the powersupply 0V point. Add the optional 100R "safety" resistor to local chassis at the power supply 0V point if you want or just leave it out.
I have an EL84 Ultralinear PP Amp built exactly this way - its never given even a hint of hum.
Old 25th October 2004, 09:44 AM   #6
845 is offline 845
845's Avatar
Hi!
I usually use two-point system of grounding. First point-signal ground Is close to RCA input socket.The signal ground bus begins in this point and comes to an end on connection of a loudspeaker .All earthen points of the amplifier are connected to this bus.
Second point-power ground . The power ground bus begins in this point which is close to power transformer and comes to an end on the last capacitor in the power supply.All earthen points of the PS are connected to this bus.
In my 845 amplifier I use three-point ground system.This amp have two power transformers.
First-signal ground.
Second-power ground for the driver gtage (325VDC)
And third point-power ground for the end stage (1kVDC)
These ways of grounding it is taken from :
[URL=http://www10.big.or.jp/~dh/inside/abo.html]
I am very sorry for my English.
File Type: jpg resize of resize of resize of picture 117.jpg (87.4 KB, 228 views)
Old 25th October 2004, 10:26 AM   #7
Account Disabled
Confused again!
With bus ground, how to connect the ground from reservoir caps, CT of filament windings and main’s earth?
Also, there are reservoir caps near the input stage and phase splitter (you know,for better filtering).Where to connect them?
And if I have a chassis ground btw input RCAs(front of the chassis-near the input tube), how to connect over there the main's earth if the main socket is on the back of the chassis?
I think something like this in the attached foto is more simple!
I don’t know if it’s better so, heeeelp!
Old 25th October 2004, 10:38 AM   #8
pedroskova's Avatar
Hi, a good explanation may be found below.
Kurt Strain's Grounding Tutorial
Old 25th October 2004, 02:19 PM   #9
Account Disabled
Thank you guys!
Nice articles.
I like those plumbing examples.
Thread Tools
earthing advice on a US amp woodturner-fran Tubes / Valves 7 16th January 2009 01:25 AM
U-links for earthing EC8010 Tubes / Valves 0 27th December 2007 05:43 PM
earthing!!!!!!!!!! resident Tubes / Valves 48 22nd December 2004 01:20 AM
earthing metebalci Tubes / Valves 2 23rd April 2004 03:35 PM
Page generated in 0.24795699 seconds (73.80% PHP - 26.20% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
