| diyAudio Sponsor | ||
i'm interested in building a simple valve preamp.any comments on this design,improvements etc?
anyone know of other simple designs using ecc83 or 82's(i can get those easily). |
#2 |
Here's a design for you
http://cvd.scorpiorising.ca/docs/Mountain_River_PCB.pdf To keep it simple, just don't use the RIAA section |
#3 | |
cheers. garbage |
#4 |
Hi!
here's good one for you. |
#5 |
see if this works.
http://img91.exs.cx/img91/849/12ax7pre.jpg p.s. thanks for the cj schematic,i think i'll try that one. |
#6 |
The preamp you referenced will work.
12AX7 tubes were used in some of the classic 50's and 60's tube preamps. However, most of them had cathode followers or were designed to drive tube amps with 250k input impedance. For line stage duty, current practice is to choose more linear tubes, forgo feedback and pay attention to the power supply.. Also, tubes with lower mu are generally used. There are a lot of line stages in the forum that look fantastic. Check out Frank's Line stage, for example. If I were inclined to build someone else’s design, that’s one that comes to mind. Good luck; Doug |
| Big valve preamp | beamnet | Tubes / Valves | 20 | 27th May 2007 11:14 PM |
| valve preamp | damianl | Tubes / Valves | 4 | 7th July 2006 08:42 AM |
| Valve preamp | lukecon | Tubes / Valves | 5 | 3rd April 2006 09:54 PM |
| Advantage of Valve Preamp? | Lloyd1986 | Tubes / Valves | 7 | 3rd April 2005 11:08 AM |
| simple valve preamp | mr l | Tubes / Valves | 2 | 21st October 2004 01:10 PM |
| Page generated in 0.08408 seconds (85.81% PHP - 14.19% MySQL) with 11 queries |
