Help valve newb salvage some old TV tubes
Old 19th October 2004, 08:33 AM   #11
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
Hmm... It's not like I don't know ohm's law, it's just that I don't know anything about valves, not electronics. I don't think that every electronist has the obligation to be a valve guru. And I have to admit that I don't feel the greatest temptation to become one.
After all, hasn't anyone ever built an audio amp with these tubes?
we all love a good ol' stereotype until it's against us
Old 19th October 2004, 10:54 AM   #12
mcs is offline mcs  Denmark
Originally posted by mr_push_pull
After all, hasn't anyone ever built an audio amp with these tubes? [/B]
Of course. Just look for circuits with EL86 and ECL86 - they are the "radio" versions of your tubes. The EL86 was often used in Philips radios, and the ECL86 is quite common also. I could probably dig up some circuits for you, but try Google first...
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 19th October 2004, 10:59 AM   #13
[i]Just look for circuits with EL86 and ECL86 - they are the "radio" versions of your tubes. The EL86 was often used in Philips radios, and the ECL86 is quite common also. I could probably dig up some circuits for you, but try Google first...
Best regards,
Mikkel C. Simonsen [/B]
So ECL86 is the radio version of PCL86 and EL86 (not EL84) is the radio version of PL84?
Old 19th October 2004, 11:08 AM   #14
Yes, the E, U and P tubes with the same number are often the same, but not always. I guess the PL84 was made for TV use first. And then it was decided to make an E version, but the 84 number was already in use - but that's just a guess. The EL84 is not available as a P tube for some reason.
Best regards,
Mikkel C. Simonsen
Old 20th October 2004, 12:40 AM   #16
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Hmm... It's not like I don't know ohm's law, it's just that I don't know anything about valves, not electronics...
...After all, hasn't anyone ever built an audio amp with these tubes?
Aha! I beg your pardon, I had rather assumed that you knew little about electronics. My mistake.
Line scan valves: PL504, PL509/PL519 are popular as output valves in Output TransformerLess (OTL) amplifiers. You probably know the output stage as "totem pole".
Field scan valves: 6BX7, 6BL7 have a following, but you won't get much power out of them. European field scan tended to use pentodes. In neither case was linearity a primary concern.
Audio valves: Push-pull ECL86 in ultra-linear mode makes quite a nice little amplifier. SE pentode ECL86 gives 3W with lots of distortion. SE triode-strapped ECL86 probably < 2W.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 21st October 2004, 11:47 AM   #17
Originally posted by EC8010 Aha! I beg your pardon, I had rather assumed that you knew little about electronics. My mistake.
What did you think my nickname and location meant? Didn't you know what I am and what I do?
OK, so what about ECL82 valves? I can get two unused EL86's and two unused ECL82's. It would be nice if you took a look at the links above and make a recommendation for an amp that can be built with these valves. I'd really appreciate that
And the output transformer is not such a concern. I think I can get one at a junk shop and rewind it.
Old 21st October 2004, 12:14 PM   #18
EC8010's Avatar
ECL82 is fine, and some people get quite enthusiastic about them. EL86 is a rather different kettle of fish and is meant for driving high impedance loudspeakers directly (have a look at the data sheet on Frank's site) - it can be used for headphone amplifiers. Any of thos amplifiers in the links should be fine - they're all derivatives of the Mullard design.
Toroidal mains transformers have been successfully used as output transformers in push-pull amplifiers, but the anode currents need to match exactly to avoid core saturation.
Help valve newb salvage some old TV tubesHide this!Advertise here!
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Salvage value? Mark2727 Class D 9 13th April 2009 05:32 PM
Newb planning to build a Valve Amp ValveAmpDubai Introductions 3 9th March 2009 09:57 PM
Lots of valve / tubes for sale in Leeds (UK) Merlinb Vendor's Bazaar 0 12th October 2008 05:24 PM
Cables/tubes for Valve Amp hyper04 Tubes / Valves 14 24th January 2005 11:50 PM
