Grounded Grid wiring question
Old 15th October 2004, 07:28 AM   #1
ultrachrome is offline ultrachrome  United States
Default Grounded Grid wiring question
I'm finally wiring up my Grounded Grid preamp after much delay. Partly due to me deciding to hand wound a toroid to power it.
I have some MIL-W-16878 stranded 22 gauge wire. Is this sufficient to provide 12V 1A DC (from LM340T) to heat three 12AU7A's or should I use something thicker? The tubes will be daisy-chained.
Thanks.
Old 15th October 2004, 10:11 AM   #2
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
You need something slightly thicker..or you can double up ofcourse
22 awg max current is 0.92A
http://www.powerstream.com/Wire_Size.htm
If you can see the speaker cone move...it's not hifi.
Old 15th October 2004, 05:25 PM   #3
Thanks, I saw that link in another thread but I don't understand the difference between "amps for chassis wiring" and "amps for power transmission".
Old 17th October 2004, 03:56 AM   #4
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Use 20 awg solid Rat Shack hookup wire, should do just fine!
Wayne
Old 17th October 2004, 03:36 PM   #5
Sherman is offline Sherman  United States
Chassis wiring = short runs between components in the chassis.
Power transmission = running power over distances (say between an external PSU and amp chassis).
I would think that running wire from an internal PSU to a heater pin on a tube would qualify as chassis wiring if the distance is relatively short like a couple inches.
However, if in doubt 20AWG is cheap and available anywhere.
--Sherman
Grounded Grid wiring questionHide this!Advertise here!
Hum in Grounded Grid Pre g(f(e)) Tubes / Valves 4 18th March 2008 02:28 AM
Grounded Grid jswen Tubes / Valves 0 17th May 2006 11:48 PM
Grounded Grid Help gelder Tubes / Valves 8 11th December 2005 02:00 AM
Grounded Grid pre amp-- help please andrewe1 Tubes / Valves 10 17th April 2004 02:37 PM
Grounded Grid Trafo question ultrachrome Tubes / Valves 3 21st November 2003 03:53 AM
