| diyAudio Sponsor | ||
#11 |
diyAudio Moderator Emeritus
Mr. Stan White, who designed and marketed the POWRTRON amplifier in the early 1950s, claims that a triode is a voltage ampilifer, a pentode is a current amplifier and an ultralinear connected pentode is a power amplifier. He says that only a power amplifier is suitable to drive a dynamic load such as loudspeaker.
He also had a few scathing things to say about D.T.N. Williamson's amp design. If you're interested, you can read more of Stan's opinions at this link. |
#12 |
Don't click or you'll meet some unfriendly javascript.
#13 |
I think its http://www.stan-white.org/ (.org instead of .com)
Then click on "Documents" |
#14 |
This article by Stan White is full of misinformation and show a lack of technical knowledge.
Some things... In the article it says that Williamson suggested a 2 chassis design as he thought that this would be reduce hum, this is not true. In the original article in Wireless World Williamson described a single chassis with amplifier and power supply, in the 2nd follow-up article he also described an alternative design using 2 chassis but this is not described as superiour and is not specifically recommended. In the article an amplifier with 807's and "an American version of the Williamson" are described. These amplifiers are not Williamson amplifiers, they could be based on the Williamson circuit but was never designed by Williamson. 807's even though they are very good tubes are far away in performance from the KT66's used in the original. The description of the split load phase inverter used in the Williamson repeats the same common mistake that is abundant in descriptions of this circuit, that is claiming that output impedances from anode and cathode are different. This is not correct and has been described many times, for instance by Morgan Jones in his book, a more thorough analysis can be found here http://www.aikenamps.com/cathodyne.pdf The Williamson amplifier of course have its weak points that can be improved but I dont think these kind of articles with many errors can help anyone. Regarding Stan Whites claim that an amplifier should have what he call "power feedback" the fact is that most modern speakers are designed to be driven by a voltage source with low impedance, it is of course possible that it would be better to design speakers and amplifiers in other ways but with comercially available speakers I believe that a low impedance amplifier, (with voltage feedback) is the best solution. It is noticeable that even though it is 50 years since the Powertron came on the market no one else have presented a similar amplifier, if it would have been soo good as Stan White say it is I think many companies would have taken the chance to copy the concept.... Regards Hans |
#15 |
In any discussion of the split load phase inverter sooner or latter the article of Mr. Preisman is sited.
His prime arguement is that so long as the load impedances on the anode and cathode are equal the outputs will be equal in phase and magnitude REGARDLESS of the differing source impedances. I'm about to sit down and work through this paper - for the second time, I bailed out half way thru' last time. Has anyone done this - i.e. is there INDEPENDENT confirmation of Mr Preisman's article anywhere. PLEASE - The last time I saw this discussed on a forum similar to this one, the debate degenerated into heated personal abuse and no conclusions were reached. Lets not repeat that here. I confirm that Morgan Jones does'nt agree with Preisman and advocates the use of a "build out" resistor in the cathode output to equalise the source impedances. I built his little EL84 Amp which uses the split load phase inverter. In the end I connected a dual trace oscilloscope to the anode and cathode (to keep the loads equal) and then adjusted the "build out" resistor in the cathode output empirically to give exact balance at 120kHz. The resistor value I ended up with was about 1/5th the value that my calculations of the source impedances suggested would be required. I guess that puts me in "CONFUSED" camp. |
#16 | |
I am not either going to be involved into a debate about Preismans text, but he explains why the output impedances are equal as output impedances are usually defined and measured. If you have Spice it is very easy to confirm that Preisman, (and Morgan Jones's later text) is correct both for the equality of the impedances and the unexpectedly low value of it. I have done Spice simulations and also built split-load inverters with various tubes where I have confirmed both the value of output impedance and that they are indeed equal. However I can't explain why you come to a different result with your measurements. Regards Hans |
#17 | |
There seems to have been a bit of sniping going on in those days, including Stan White's attacks on electrical engineers in general and on D.T.N. Williamson in particular, plus Williamson's own article decrying the "so-called ultralinear" concept of Hafler & Keroes. Professional jealousy, perhaps? |
#18 |
It's pretty easy to measure for yourself that the split-load really does balance and that White is full of it. BUT... you absolutely MUST ensure that the plate and cathode loads are equal and that means buffering BOTH identically and probing at the output of the buffer- sticking most scope probes right on the cathode or plate will unbalance things sufficiently to throw you off. That implies that the balance will only hold if the load is a class A stage; either a buffer, class A diff amp, or class A output stage.
Conceptually, you're forced to have cathode and plate balance because of Kirchoff and Ohm's laws.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#19 |
I just read Stan White's document and here are the errors I found just from the top of my head.
1. There was a pure Williamson amplifier offered on the American market - the Radio Craftsmen 500. 2. Williamson did indeed work for a tube company when he designed the amplifier but he was actually working for the Ferranti transformer company by the time the article appeared in Wireless World. 3. Marconi Osram did at the time produce a triode similar (and better) than the 2A3 - the PX4. Williamson in the article states that the KT66 was chosen because of low cost and availability and its triode-connected characteristics were similar to the PX4. I am sure there are other errors in the article. The basic improvements one can make in the Williamson are simply changing the operating points on the 6SN7's to a more linear region of the tube's characteristics. John |
#20 |
Hans
< It is noticeable that even though it is 50 years since the Powertron came on the market no one else have presented a similar amplifier, if it would have been soo good as Stan White say it is I think many companies would have taken the chance to copy the concept.... > Hello Hans, You are wrong. The best tube amplifiers made by AUDIO RESEARCH the Powrtron power-feedback topology. see Jean Hiraga: "Initiation aux amplis à tubes" Cheers, PP |
| Estimate Miller of Triode Strapped Pentode | dsavitsk | Tubes / Valves | 3 | 13th January 2009 06:27 AM |
| Wanted Triode strapped curves for pentode of ECL82. | Shoog | Tubes / Valves | 2 | 28th March 2007 09:03 PM |
| 5763 Triode Strapped | wrenchone | Tubes / Valves | 3 | 5th August 2006 07:59 PM |
| Recommendations needed for designs of PP pentode strapped as Triode | percy | Tubes / Valves | 24 | 22nd October 2004 10:03 PM |
| E180F triode-strapped. | jim | Tubes / Valves | 15 | 16th September 2003 12:00 PM |
| Page generated in 0.14612 seconds (83.55% PHP - 16.45% MySQL) with 10 queries |
