Found some EC8010
Found some EC8010
Old 14th October 2004, 02:15 PM   #1
markanica is offline markanica  Netherlands
Default Found some EC8010
Hi all,
Just found a pair EC8010 tubes on a hamradio exchange market
At the pins I can see they are used, they look ok though.
I haven't tested them yet, hope they are ok.....
Did a search on this forum and got lots of threads with EC8010 in them, but they all appeared to be someones nick
Found data sheets plenty, but like to know what was their intended use and in which diy-circuits they excell.....
On the bottom of the tubes is a '6' in the glass and on top one tube is the code 529, the other says 536
Any further info on these tubes would be great
Mark
Old 14th October 2004, 02:41 PM   #2
Geek is offline Geek
Geek's Avatar
Looks like a good general-purpose tube
That open construction will look funky!
Here's some examples I Googled:
http://www.wdehaan.demon.nl/mono/mono/56872.html
http://www.vt52.com/diy/myprojects/amps/lcr/lcr.htm
http://www.vt52.com/diy/myprojects/a...e/epilogue.htm
And more!
http://www.google.ca/search?num=30&h...er&btnG=Search
Old 14th October 2004, 08:39 PM   #3
Hey Geek,
Thanks for your reply, btw. interesting website you got. Spent some time reading stuff....
Saw some GM70 and 300B amps using EC8010 as drivertube, but has anyone experience with EC8010 as small signal amplifier tube especially concerning microphonics?
Mark
Old 15th October 2004, 05:45 AM   #4
Geek's Avatar
I have personally found microphoniciness of a tube particular to brand of the tube. Not with the 8010 specifically, but all tubes in general. Sylvania for example, have one of the nicest tones, but all are microphonic (even a Sylvania 7025 I have is microphonic), while some other lesser-known-to-audiophile brands, like Rogers, sound "darker" than the rest, but you can tap them with a screwdriver all day and not hear one "ping".
The moral of the story is....make a test jig and try it.
My test jig consists of a breadboard where I bias the tube, usually 100K on the anode, 1K on the cathode bypassed with 10uF, ground the grid, run the anode through a 0.01uF cap out to your soundcard line input. This can be used to measure noise and microphonics.
Old 21st October 2004, 12:48 AM   #5
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Found some EC8010
WOT preamp
search for "Choky's wot preamp" here or with google
or just search for "Euridice" preamp
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st October 2004, 02:52 AM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
If you look at the TFK datasheets it should be rather obvious to see what these tubes were designed for.
Nonetheless they should be great in audio apps where you'd want both low noise and high gain.
Phonopreamps, microphone pres and MC headamp stages come to mind.
Given the tightly clamped build microphony should not be an issue unless you hit a really bad batch of tubes.
Frank
Old 21st October 2004, 12:38 PM   #7
Zen Mod's Avatar
Found some EC8010
found it ;
Old 21st October 2004, 08:42 PM   #8
Default thanks
Geek, choky and Frank,
Thanks all for your replies
So these tubes could come in my next phono preamp ( now i use 12ax7's, with a ecl85-0a2 series regulator for each channel for that )
Currently i'm working on a 6c33 circlotron otl, that one gets my full attention first. Takes a lot of time though, since i'm not an electronics scolar at all. But great satisfaction when i get something to work properly
Bye
Mark
Old 21st October 2004, 11:12 PM   #9
Zen Mod's Avatar
Found some EC8010
yep-when I manage to stash enough 8010 and/or 8020,I'll start to make my new LR EQ phono stage with lotsa iron and those quties
Old 21st October 2004, 11:27 PM   #10
fdegrove's Avatar
Hmmm....I'm always interested in seeing the schematic of that preamp if you have it...
There's a thread here entitled "OTL" in case you're interested.
What's the target poweroutput for that amplifier?
Frank
Found some EC8010Hide this!Advertise here!
CHOKY'S EC8010 preamp brianco Tubes / Valves 6 23rd January 2017 08:13 PM
Ping EC8010 .... moray james Analogue Source 15 22nd April 2009 08:09 AM
New EC8010-VT52 Amp gianluca Tubes / Valves 9 14th May 2006 10:16 PM
Time for EC8010 expose of unipivot arm drawings ktigerb Analogue Source 4 11th August 2003 08:11 AM
5842 or EC8010 with OPT! Hauke Tubes / Valves 27 7th May 2002 04:30 AM
Copyright ©1999-2017 diyAudio
