I’d like to submit and discuss the schematic of an integrated amplifier (direct connected to a CD-player … without pre).
We (no-profit association – Agorà) would like to realize this project together with the child that take part to the “Corso di Elettronica” (electronic course, promoted by our association). Since I’m not an expert in Electronic, I’d be very grateful if somebody could help us in this adventure. Points to be defined: Current setting of 6S45P and bias of 300B: 1) 15-20 mA …with “combined” anode load (H + R; i.e. H=50H/400DCR+ R=3.000 ohm). 2) 35 mA … with “pure” choke anode load (i.e. 170H/2000DCR). 6S45P-Bias: 1) vacuum tube diode on the cathode (which one?). 2) battery on the cathode. 3) RC on the cathode. 4) RC on the cathode (with R being a potentiometer … in order to match the two 6S45P). Input transformer: 1) Sowther 3575 in configuration 1:1 2) Sowther 8920 in configuration 1:1 having the two secondary in parallel. 3) Sowther 8920 in configuration 1:2 … with a less power input-driver tube (i.e. ECC99). Power supply: 1) L2 and L4 --> 30H/100mA/190DCR 2) V ? 3) C1=160 uF, C3=80 uF, C5=1 uF |
#2 |
#3 | |
Nice looking project!
I don't quite understand the need for a combined choke. If it's purely dc considerations it is possible to adjust the anode voltage as you have a separate PS. For 6S45 even 50H would suffice IMO. So my choice would be 50H @15mA. 6S45 bias Vacuum tube? Don't think any will give you such a low bias at 15mA, let alone 35mA. If you still think you must use it try several 80 in parallel (2-4?) IME rechargable batteries work well with the 6S45. Just don't ask what type as they all sound annoyingly different (as capacitors) in this position. As you have an input transformer it may be a much better sonic solution to connect the battery in series with the transformer windings. regards |
#4 | |||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
The 6S45 choke loaded will allow the required 74V Peak at around 0.5% 2nd harmonics, so the driver stage will be very linear, using a LNR Diode will not likely make things significantly better. Then to correctly Bias the 300B add a small adjustable resistor in series with the 6S45-PE Anode Load choke which allows the 300B Bias to be trimmed. The suggested operating points will allow around 6 - 7 Watt RMS @ 5% THD (mostly 2nd Harmonics) without using LNR Diodes and will require around 1.3V RMS for full output with a 1:1 Input connection. Sayonara |
#5 |
KYW,
thank you for your replay. Specific questions: 1) 6S45P Operating point. OK for your suggestion. However ... how to obtain the bias for the 300B with only 10 mA ? We should have to add a 17Kohm R (better ... 17.000-400 ohm of the choke) in series with the anode choke. Can the high value of R represent a problem ... or make worse the operating condition of 6S45P ? 2) Battery bypassed by a capacitor on the ground lag of the input Transformer. OK...but which V value and C value ? ... 2.4 V ? ... uF ? 3) LNR diode on the cathode of 300B. (what does LNR mean ?) Why do you believe that the use of 6CG3 may represent a problem ? Since it has been largely experimentated and tested by Dennis Boyle ... why not to use it ? Dennis Boyle told me that a mixed bias is better than a fixed bias. I do not know the reasons of such assertion. However, I believe that it must be important ... if he utilizes, in addition to the stacked supply, a LNR diode on the cathode. Furthermore, eliminating the LNR diode ... what we need on the cathode of 300B ? ... nothing ? ...or a Capacitor ? |
#6 | |
For analog...
...The combined load (choke+R) is necessary to obtain the bias for the 300B. Alternatively, with 15 mA ... how to obtain 70-75 for the bias ? |
#7 | |
John |
#8 | |
John |
#9 | |
Jlsem,
I do not understand the problem with 5AR4 ... Quote:
Please, may you better explain the problem ? |
#10 | |
jlsem, you can take B+ ad libitum from either side of the DH rctf. eliminating the pot (or two matched R's), it does not change anything except you get better and more equall and linear exploatation of the rctf. cathode, compairing with the case when it's taken from one side.Or better try a separate,good, with e- static shield,bifillary wound heater T/X!! Regards, Yugovitz
Bird lives! |
| JLH Direct-Coupled High Quality Stereo Amplifier | kimbo | Solid State | 98 | 22nd June 2009 06:58 PM |
| GM70 SET direct coupled 2x30W monoblock amplifier | noyan | Swap Meet | 3 | 15th February 2009 03:48 PM |
| An intriguing 300B SE-direct-coupled-amplifier | Antonio Tucci | Tubes / Valves | 27 | 8th February 2006 09:34 AM |
