| diyAudio Sponsor | ||
#2 |
The 1660 is presumably wired 4.5:1, right? Looks fine although i am not particularly fond of non-bypassed cathode resistors. Consider replacing the resistor with a couple of NiCds as well.
#3 |
analog_sa:
yes 4.5:a SE to line output. What type of NiCd do you reccomend? The person i got the schematic from used anoher value POT, im going to use as seen 250K, i dont have to change any values because of that? the one i had on mind was the 100k |
#4 |
Is this a linear pot being log-faked by the 100k resistor? Then you would also need to reduce the resistor value in order to get a smooth pot action. Or just use a log pot and remove the resistor.
The batteries i currently use are NIMH and come from 900mA/h cellphone batteries. I use 2 cells for 2.4v bias. |
#5 |
i have built this nice pre-amp (called: Euridice) with the LL1660/18mA. In the normal connection the output level is too much. IMHO you don' t need 4,5:1. Batterie biasing is a good way... Greetings Barossi |
#6 |
analog_sa:
To be honest i dont know the type of the pot, its an alps black beauty marked: 643t 250KX2 I will look it up. barossi&analog_sa: As i understood you both are using batteries instead of cathode resistor. What have you compared with and what was the results? |
#7 | |
It's pointless talking about the sonic results if the PS is not shown. I use 83 rectifier with low DCR transformers and chokes (Lundahl) and Cerafine caps. |
#8 |
analog_sa:
The potentiometers are logaritmic, perhaps i can just remove the 100k? |
#9 |
It is not essential. I guess it's only purpose is to keep negative bias for the tube if the wiper goes AWOL.
#10 |
If you decide to use NiCd battery for this, just make sure it can stand the current. Look in the datasheet what charging current is OK.
It is also possible to use battery for bias and no cathode resistor at all. For bypassing the cathode resistor, it is good to use tanthal electrolytics I´m told. |
| I'm looking for 417a/5842 Preamp Schematic without any Transformer, any suggestion ? | calico88 | Tubes / Valves | 7 | 31st March 2007 07:46 PM |
| What's the best 417A & 437A? | Triod lover | Tubes / Valves | 3 | 23rd January 2007 02:11 PM |
| 417A Line Amp | apassgear | Tubes / Valves | 51 | 31st March 2003 01:23 PM |
| Page generated in 0.10077 seconds (75.84% PHP - 24.16% MySQL) with 11 queries |
