hello everybody,
long time so see, haha, i had to much work in the holiday, but now the schoolyear has began again, i'm on the hifi trail again. This summer i have build my speakers, open baffle 38cm woofer, full range (150hz-12000hz) coral drive (it is visaton but with the coral paper cone, it was made by coral but with the visaton name on it just when visaton took coral over) and a tweeter (phillips, i will put a ribbon in it) i'm gonna buy a dcx 2496 to get it wright. but the amps ? i'm still missing an amp, i need three of them, hahaha. In time i wanna replace the midrange and tweeter amp by a tube amp. So a half year ago i asked if anybody know the trio el84, and a lot of reactions came up. Everybody told me this amp was very good and it was worth it to make it work again. I have found the schematic and i wanna post it here. (the guy from who i got the things said that was the most fun for listing he ever had). the schematic has left out the phono stage and added a loudness on to it. But does anyone has comment on the schematic. I mean is there something which can be done better ? like in the power supply ? this will be my first tube amp project. Now that i have build the speakers, i'm on to hifi-heaven. anyway thanx guys for all the help, if i get it wright (the speakers with the dcx 2496 i will take photo's and some measurments) here you can find the scheme http://www.jogis-roehrenbude.de/Lese...EL84_StAmp.htm and this is the scheme
| EL84 push pull | slideman82 | Tubes / Valves | 4 | 19th June 2009 03:40 PM |
| advice on an EL84 Push pull Amp schematic | colin.hepburn2 | Tubes / Valves | 6 | 2nd June 2006 04:02 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| I need help troubleshooting a EL84 push pull amp. | pingfloid | Tubes / Valves | 7 | 24th June 2005 05:28 PM |
| EL84 Push Pull amp. | hacknet | Tubes / Valves | 8 | 23rd September 2004 05:53 AM |
