diyAudio Sponsor
Old 9th October 2004, 04:17 PM   #1
james_b is offline james_b  United States
Question Best place to use 2 Jupiter Bee caps in tube amp?
Which would be a better place to utilize 2 Jupiter Beeswax capacitors in a tube amp?
Choice one: one each in the location between the right & left
RCA inputs and the dual volume control,
or choice two: one each between the plate of the driver tube and the grid of the output tube.
This is in a 4 tube pushpull pentode amp. Thanks for your opinions.
Old 9th October 2004, 05:10 PM   #2
Yugo's Avatar
Default Re: Best place to use 2 Jupiter Bee caps in tube amp?
James,
I'll go for 2nd option,because if you don't have DC at the output of your previous stage you can ommit input cap.Especially if you use attn. rather than pot!
Yugovitz
Bird lives!
Old 10th October 2004, 01:02 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hmmm...sounds expensive and dubious (think of all those leaky wax caps from old radios......). I say #3, e-Bay 'em for some 715P's.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 10th October 2004, 04:20 AM   #4
rcavictim's Avatar
I'm with Tim. Ebay those snake oil capacitors. If you absolutely HAVE to use them. Put 'em in the input circuit so that when they fail they won't degrade the circuit or cause catastrophic damage.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 10th October 2004, 07:09 AM   #5
analog_sa's Avatar
Not so fast. These caps contain harmful substances (snake oils)that need to be disposed of in responsible manner. I am willing to do this for free as i already have experience with this vile brand. Pls send a pvt mail to arrange collection.
If you still feel brave to use them keep in mind their transparency is highly addictive and likely to cause long term dent in your audio budget.
Old 10th October 2004, 06:00 PM   #6
Default caps
Its easy to ignore dimwits who post negative comments about a product they have no experience with, you know what they say about opinions (of the uninformed). Personally I have in the past upgraded to Jensen PIO caps and they were a definite improvement, so I am looking forward to trying the Jupiters.
Old 10th October 2004, 08:51 PM   #7
Yugo's Avatar
Default Leaky wax caps!
Tim
It is interesting that many people claim wax caps(along with oil caps) can be leaky after long time of exploatation.How it is possible when,as far as I know,beeswax has dielectric constant close to that of PTFE!?
Yugovitz
Bird lives!
Old 10th October 2004, 09:39 PM   #8
kevinkr's Avatar
I haven't tried the jupiters myself yet, but I have listened to an amplifier that used them, and I will say it was a pretty darn good sounding amplifier. I have been using the Jensen copper pio caps for some years now and haven't seen one fail yet. I think the Jupiters are worth trying, and bear in mind that all those "unreliable" wax/paper caps were usually decades old in most cases by the time they failed. Modern electrolytics often don't do a whole lot better... Just be careful not to overheat the leads when installing, and check dc leakage after installation.
Old 10th October 2004, 10:53 PM   #9
analog_sa's Avatar
The prob with the Jupiters is they appear to be very temperature sensitive and will become leaky if exposed to high temp over extended period of time. I have always been careful and never had a problem but realise that with a new brand, obviously not following the traditional technologies, long term reliabilty is unknown and probably much inferior than film types. The Jensen/Audionote seem to show a lot of reliabily problems after 5-6 years of use.
So, if you would like to treat your caps as a long term investment, buying russian teflons is probably a smarter move - no doubt they were designed to withstand atomic blast temperatures
Old 10th October 2004, 11:42 PM   #10
Sch3mat1c's Avatar
Default Re: Leaky wax caps!
Ok, so WTH does K have to do with anything? Is glass then as bad as an electrolytic, simply because their K's are similar?
You sir clearly know nothing about capacitive materials.
Tim
help jupiter beeswax caps direction tomat Parts 5 12th February 2009 06:38 AM
best place to by highend caps cicotte Parts 3 23rd November 2008 02:11 PM
EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? jarthel Tubes / Valves 27 9th June 2006 12:04 AM
coupling caps? RTX vs Jupiter wax AudioGeek Tubes / Valves 6 6th July 2004 12:43 AM
Wheres the best place tu buy caps? CryingDragon Solid State 5 2nd October 2002 12:27 PM
Page generated in 0.12365 seconds (81.25% PHP - 18.75% MySQL) with 10 queries
