| diyAudio Sponsor | ||
#11 |
I would recommend using a higher voltage transistor for the current source. I have submitted a much more effective source as an alternative, depending on beta of the transistors the effective tail resistance can be several meg ohms. To change current levels just replace R1 with a smaller value - 33 ohms would result in roughly 20mA of current. Any transistor with VCeo 100V with a beta of 100 and an HFE of 60MHz will give good performance. Note resistance of R2 can be increased if you are using higher voltage negative rails, current flowing in Q2 should be typically > = 10% of Q1 collector current. (Not critical) In the case of a -40V rail I would probably make R2 about 22K.
Pay attention to the dissipation in transistor Q1 (about 0.8W) use a device in a TO-202 package with a heatsink. |
#12 | |||
diyAudio Moderator Emeritus
However, I don't know if the latter objective is really valid. If I go with a solid state current source, it would be easier and potentially more stable to use simple capacitive coupling. What concerns me is that I could easily exceed the maximum dissipation of the PN2222A (.43 W). Quote:
I must be careful of exceeding the max dissipation of the PN2222A and, for this reason, I might have to limit the negative rail to just a few volts. Quote:
#13 |
The ring of two is an excellent choice here. And, yes, I misreciprocated in the R1 equation.
There is no shortage of reasonably fast higher-voltage NPNs in the 1 to 2 watt Pd range.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#14 |
Would MJE340 (VCEO max = 300v, Dissipation 10W) be a suitable choice for Q1 in the "ring of two" CCS? I'll probably use PN2222A as Q2, since I already have a couple of those.
#15 |
I would recommend fairchild KSC2682 if you can get your hands on it. The low minimum beta of the MJE340 doesn't thrill me, and the 2682 is well specified for operation in the current region we are interested in, and on a proper heat sink can dissipate up to 8W. Try to find a transistor with a minimum beta of around 100 at less than 100mA, and try to avoid anything much over 300. Vceo should be at least 30% greater than the worst case operating voltage from collector to emitter. I like fairly high FT devices, typically something with a 60MHz rating.. What is the V- rail going to be for the CCS? As to whether or not you can use 2N2222 that depends on the negative rail, if it is much over -25V I would reconsider.
#16 | |
OK, I'll try to get a KSC2682.
I plan to use two ring-of-two CCSs, one for the 6SL7 with neg. rail of ~50v and the second for the 6SN7 with no neg. rail since the grids of the 6SN7 will be at about +57v owing to DC coupling that I plan to use between 6SL7 and 6SN7. Same difference, though, when it comes to the voltage the CS will see. However, I thought maybe the voltage wouldn't really matter for Q2, since its collector will see only the Q1 b-to-e voltage + its own b-to-e voltage (total about 1.2v?) Anyway, if I'm going to go out and buy some KSC2682s, then I might as well buy some other higher voltage transistors for Q2 at the same time. My only limitation is that I'm in Jakarta and electronics items are not always easy to source. BTW, would it be OK to use the KSC2682, if I can find them, for both Q1 and Q2? |
| Optimal operating point for 7N7/6SN7? | pftrvlr | Tubes / Valves | 5 | 16th December 2008 05:43 PM |
| Operating point for 6GK5 | AKSA | Tubes / Valves | 6 | 6th October 2008 04:21 PM |
| 6N6P and 6SN7 Operating point suggestions | dsavitsk | Tubes / Valves | 2 | 17th September 2006 01:50 AM |
| Best Operating point for a 2A3? | sgerus | Tubes / Valves | 10 | 2nd August 2006 01:31 AM |
| 6sn7 operating points | AudioGeek | Tubes / Valves | 15 | 8th September 2005 01:59 PM |
| Page generated in 0.11200 seconds (81.07% PHP - 18.93% MySQL) with 11 queries |
