| diyAudio Sponsor | ||
According to the Svetlana, the 6N1P & SV83 mu stage is suitable for driving a SE 845.
see technical bulletin: http://www.svetlana.com/docs/TechBul...noteNO.27.html Has anyone built something like this? Thanx for any comments about this combination. |
#2 | |
Personally, I'd use something like a D3a in pentode. |
#3 |
If you read the article, 100Vrms with 0.45% THD. This is quite good!
The output impedance is quite low, 100 ohms, so such an amplifier built with the mu stage ought to take a 211 by simply screwing in the new tube and back off the fixed bias setting... Yeah you could use D3a et cetera, but this is cheap to build using tubes that cost less than usd$10.00 each. -- Jim |
#4 | |
BTW, I've never paid more than $US10 for a NOS D3a. |
#5 |
Hi Dr. Strangelove,
If you like I have a mu-stage schematic for you, based on a 6H30p and a D3a, driving a 845 on 20W. Send me an email. |
#6 |
Hi 211audio,
I would love a schematic using based on the 6h30p, d3a and the 845!!! I love those toobz. but... your e-mail button is off. So I can't email you directly... can you send me a message so I can email you back? Thanks |
#7 |
Hi, (6N1P + SV83) this is the Mu-stage schematic that I used for my Line-Amp. The sound is very nice and detailed. In fact I'm using 300V B+ and changed the 6N1P's Rk=2.2K. I had tried the D3a instead of SV83, but I don't like the result! The overall sound is too bright and forwarded, a bit like metalic sound? The D3a that I used is Siemens from eBay http://cgi.ebay.com/4-x-D3a-Siemens-...QQcmdZViewItem
Is there anyone know why? |
#8 |
I suppose SV83 is EL84 without internal connection G3-K.
Probably it has more precision winding of grids, or just more strict limits in datasheet to meet better linearity needed for TV amplifiers where 6P15P (original name of SV83) were used. Tubelab, did you torture them? How different they are really from 6P14P?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#9 |
Hi Dr. Strangelove,
My email button is on now, but I can't send you a mail because my account is under moderation, due to my first steps on this board. About Siemens D3a: All of my amps utilized the D3a penthode and I can't say anything else than that it maybe have something to do with the way you bootstrapped the tube. I've used it in several 300B and 211 amps. |
#10 |
dr.strangelove3,
The schematic you have attached to your reply is not a mu-stage (Alan Kimmel) but a mu-follower circuit. That is something totaly different.... 211audio |
| SV83 vs EL84 | Brit01 | Tubes / Valves | 5 | 26th January 2009 03:10 PM |
| driving 845 push-pull with a signal from a 300B SE stage | Antonio Tucci | Tubes / Valves | 1 | 20th February 2007 08:04 PM |
| driving your power stage | nhuwar | Tubes / Valves | 23 | 20th January 2007 05:01 PM |
| Need sv83 tubes | mbcouple | Swap Meet | 2 | 9th August 2004 11:52 PM |
| RC-coupled stage using ½ 6N1P | Mikael Abdellah | Tubes / Valves | 2 | 12th March 2003 09:52 AM |
| Page generated in 0.11135 seconds (79.06% PHP - 20.94% MySQL) with 11 queries |
