| diyAudio Sponsor | ||
Account Disabled
The second arrangement is a common one. But I found a PSU with the first one, taking the HT from the CT of the transformer.
Which is better and why? |
#2 |
The cathode in the 5U4 and similar rectifier tubes is a resistor end to end. If you pull the DC output from the tube out of one end of the cathode the most cathode emission will be concentrated on the end of the cathode you are using as the output. Over time the cathode will wear out faster because the other end of it will not be stressed as highly and the emissive layer coating will still be fresher than the side that was connected to the load. By using a center tapped filament transformer more equal cathode loading is achieved and longer tube life is the result. The center tapped filament winding costs more money to make the transformer so it is seen less often in consumer gear.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#3 |
Account Disabled
@rcavictim
thank you for detailed explanation.So go with CT filament winding! Is there any voltage dropped at the filament winding?It's like a choke. But with 5 - 10 turns of wire (I guess) there's not too much resistance,right? |
#4 |
Voltage drop in the filament transformer winding to the B+ will be so small as to be almost immeasureable in any practical sense of the term.
#5 |
Account Disabled
I'm building a preamp and a phono right,now.I like to use tube rectifiers and Shindo style filtering.So, I'll try this CT technique.
Thanks for help. |
#6 |
Resident,
If your current requirements for the B+ are low, which wouldd be the case in a preamp, why not go with an indirectly heated cathode dual rectifier like a 6X5 octal or 6X4 miniature. Then you don't need a CT fil. xfmer. These need 6.3 volts.
#7 |
Account Disabled
My preamp needs about 60mA and I'll use 1*10u and 3*220u caps and 47u near anodes of each triode.One triode at each channel.SE.
I'll go with 5U4G. My phono needs 30mA and I'll use 1*10u and 5*100u.Shindo style(in both projects).And some small about 10-20u at each triode anode of two stages. I'll go with 5V4. Why with these?I'd like to have plenty of current.I'm a little bit extreme with PSUs but not with capacitance of caps.Just what is needed for uV of ripple. |
#8 |
Hi Resident,
I like CT shematics but have some douts here. DC current will flow through the trans coil and it will not be substituted. Power trans does not have a gap, you know. So. with big current you can get distortions which hardly smoothing in filter. Igor. |
#9 |
Account Disabled
hmmmm....
So, let's put a thin gap to power trans ,too. But Or it doesn't matter? I'll think it more clearly later. |
#10 | |
Previously: Kuei Yang Wang
Konnichiwa,
The current will flow equally but it will flow in opposite directions through the heater winding halves, so it is cancelled Sayonara |
| tube rectifier psu help | milen007 | Power Supplies | 10 | 18th September 2008 03:14 PM |
| Z2b tube rectifier | bee696 | Tubes / Valves | 3 | 4th November 2006 02:45 PM |
| tube rectifier | bonsai171 | Tubes / Valves | 37 | 12th March 2005 07:07 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Tube rectifier for VDIGC tube psu | ebijma | Chip Amps | 2 | 11th March 2004 04:02 PM |
| Page generated in 0.12017 seconds (78.80% PHP - 21.20% MySQL) with 11 queries |
