6L6 class A P-P CFB amp - diyAudio
Old 3rd October 2004, 10:20 PM   #1
Account Disabled
Default 6L6 class A P-P CFB amp
This thread continues the thread 30W 6L6 UL amp.
30W UL 6L6P-P amp
I decided to make a new one because the topology has been changed to pure class A 6L6 CFB P-P amp.
Help is still needed and any comments, for everything until here are acceptable.
As I said to the old thread Iíd like to put at the phase splitter a CCS with the second half triode of the input tube.
I have attached a schem .Do you believe that this works?
Values of R2 and R3 depend on Vb and Vg-k.
R1 depends on how much Iíd like to be Vk.
How much to choose these values for good linearity of the current sink?
From the original schem I have change Va from 380V to 300V (Iím planning to use anode voltage of the P-P output stage about 300-320V) and anode loads of the phase splitter from 30K to 40K.
Old 3rd October 2004, 10:22 PM   #2
Account Disabled
And this is the original (Wayne's) 6SN7 direct coupled to 6SN7LTP driver stage.
File Type: gif sn-fq_ltp_arnoldc_05-rc_voltages_small.gif (10.7 KB, 412 views)
Old 4th October 2004, 12:58 PM   #3
Account Disabled
Newbie questions about DC and AC balance.
Do these circuits work?
For AC balance which of two to prefer?Or both work well?
Old 4th October 2004, 01:00 PM   #4
Account Disabled
And the AC DC balance circuit.
Old 4th October 2004, 09:34 PM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Everything shown looks like it'll work... mind you a pentode is more customary than a triode for CCS, and you won't burn as much voltage. (Although I'll have to check into that. The grid voltage divider would require current drawing an analog to the screen grid requirement, while depending on the perveance (for saturation voltage), the triode may end up a reasonable CCS.)
For AC balance, I would prefer balancing the plate resistors. Output stage grid leak will have little effect.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 4th October 2004, 09:51 PM   #6
Account Disabled
Hi Tim
I prefer to use 6SN7 because it's the other half of the first stage.I don't like to split the first 6SN7 to L+R channel.So I decided to use it as CCS of the PS.
ok I'll balance the plate resistors.
Can I put simple bourns type multiturn trimmers over there?
What kind of multiturn pots use at the cathodes of output stage?
Over there I need >2W pot,right?
Any good source?
I found at Aquablue swiss precision, for 20euro each.
Old 5th October 2004, 12:31 AM   #7
Sch3mat1c's Avatar
If you only make it a fraction of the plate resistances, rather than the whole thing, multiturn will not be necessary. Tubes can't even comprehend anywhere such accuracy anyway, you'll need a live spectrum analyzer to null second harmonic distortion (which is what it will affect).
In 99% of cases, a balance isn't necessary, though along with independent fixed bias, it will allow using completely mismatched output tubes.
Any good source?
::blink::
No need for a $20 ANYTHING if you ask me...
In either case, whatever voltage or current present. Ohm's law is your friend.
Tim
Old 5th October 2004, 10:01 AM   #8
Account Disabled
What do you mean with fraction?
Arenít self bias circuits more stable than fixed bias?
With a good choice of cathode resistors (value), I can match them with self bias,too.
Thatís why I decided to use pots. But I think, Iíll use Ohmís law.
Old 5th October 2004, 07:53 PM   #9
Sch3mat1c's Avatar
Say each tube of the LTP needs 56k ohms. You could use a 20k potentiometer, which at middle would give 10k on either side, allowing you to use 47k plate resistors instead (47+10 = 57, very close to the required value). That would be about one fifth, as opposed to using a whole: you could use a 100k trimmer for both purposes.
Uh, yes...but that has nothing to do with this.
Tim
Old 7th October 2004, 08:43 AM   #10
Account Disabled
Hi Tim,
I'm thinking to use a negative HT rail (-150V or -170V )at the lower end of the phase splitter-CCS to achieve about 450V total!
What do you say??Much moooore headroom!
About trim pots.
Ohm's law again and again.
Thank you for the idea.Even at the phase splitter.
Also,I don't think CFB output stages needs an ideal matched tubes.I'm not planning to use too different tubes.A pair of SV6L6 svetlana at each channel should not be so unmatched.
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 12:17 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
Copyright ©1999-2017 diyAudio
