| diyAudio Sponsor | ||
Hi all-
Can someone possibly tell me what type of phase inverter this is? I've looked at all the types, long tailed pair, cathodyne, etc. but nothing looks similar. This is on a PA amp that I'm converting to a guitar amp, so I'm planning on changing to a long tailed pair shortly. I'd really like to know what this is though for my own education. Any help would be appreciated. Thanks! Glenn
#2 |
What you got there is a plain-vanilla split-load or concertina. Advantages are simplicty and the reliance on passive component tolerances to set balance. Disadvantages include strict requirements for load symmetry and less-than-unity gain, which transfers gain swing issues to the input stage.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Thanks for the information Sy.
Looks like I'll be going for the long tail pair PI sooner than expected. Glenn
#4 | ||
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#5 |
This method is simple and it works. SInce you already have the amp and are converting it, why not leave it as it is and see what it sounds like, then convert it to another style later for comparison. Or if you like it, leave it.
#6 |
Paraphase inverters are less suceptible to load variations. Here is some education on those
![]() http://dogstar.dantimax.dk/tubestuf/paraph.htm |
#7 |
The other bad thing about cathodyne is it isn't good for much voltage, so you need an amplifier to drive stubborn tubes (like high voltage 6L6s needing 60V or more drive). This produces the Williamson driver circuit, but it has a lot of coupling caps so I don't like it. An LTP is a good way to get final drive requirements. I haven't done anything with paraphase but it seems like it has similar properties.
How 'bout that 6X8 paraphase? Tim
#8 | |
Fred had sent me a pile of them to me last fall. |
#9 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
I only have two I think, but they're so hard to use, it might as well be a pile!!
Tim
| 6J5 weird phase inverter | ThSpeakerDude88 | Tubes / Valves | 10 | 13th October 2008 04:11 PM |
| A very odd phase inverter- comments? | GordonW | Tubes / Valves | 6 | 16th August 2008 03:05 PM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 04:15 PM |
| 6C8G phase inverter | engels | Tubes / Valves | 4 | 4th February 2007 07:01 PM |
| What is the purpose of phase inverter? | RemoGaggi | Digital Source | 3 | 6th December 2006 06:09 PM |
| Page generated in 0.12301 seconds (73.39% PHP - 26.61% MySQL) with 11 queries |
