| diyAudio Sponsor | ||
#11 |
Heh, I think that's why Fred sent most of his stash to me. "Let's see what you can use them for", I believe were his words
#12 |
What could mean that numbers labelled with a triangle on the schemo ? AC peak or rms ?
32 at the driver anode and 3.6 at 6L6 grids ? If dp missing, why 48 at 6L6 anodes ? If square marked values are for DC, they are vy curious too ! Yves. |
#13 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#14 | |
there is 100v accross its plate res, and that calls for a 265v B+. Right, since this is the 6L6 Vg2 too. If so, how could the phase splitter have 280v on anode ! I just wanted to point that this schemo should be used with some caution. Yves. |
#16 | |
Squares are DC measured with a 20kOhm/Volt meter no signal. Is there something wrong with this schematic? I'm new at this tube stuff, so please pass on any wisdom you may have. I can post the whole schematic if you like. Just let me know. Thank you. Glenn |
#17 | |
diyAudio Senior Member
As Yves pointed out there's something not quite correct with the voltages (DC) as shown. Cheers,
Frank |
#18 |
Here it is.
Thanks Frank. Glenn |
| 6J5 weird phase inverter | ThSpeakerDude88 | Tubes / Valves | 10 | 13th October 2008 03:11 PM |
| A very odd phase inverter- comments? | GordonW | Tubes / Valves | 6 | 16th August 2008 02:05 PM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 03:15 PM |
| 6C8G phase inverter | engels | Tubes / Valves | 4 | 4th February 2007 06:01 PM |
| What is the purpose of phase inverter? | RemoGaggi | Digital Source | 3 | 6th December 2006 05:09 PM |
| Page generated in 0.09091 seconds (78.94% PHP - 21.06% MySQL) with 11 queries |
