SE  KT88 Amp
SE  KT88 Amp
Old 29th October 2004, 02:34 PM   #21
Mikael Abdellah is offline Mikael Abdellah  Sweden
Don't hesitate to ask me if you have any questions about the amp.
Old 30th October 2004, 02:29 AM   #22
Sherman is offline Sherman  United States
Thanks for the offer of assistance, I'll need it! In fact I have a question already. What would be your recommendation for replacing the volume pot to use with a preamp?
--Sherman
Old 1st November 2004, 07:29 AM   #23
I'm afraid I have no good advice on that. I use my amp directly connected to a cd-player.
Old 2nd November 2004, 06:30 PM   #24
I'll figure that one out, one of the ECC82 schematics I was looking at had a recommendation for replacing the pot. I can use that as a starting point.
What output transformers are you using? I'm considering Hammond 125 ESE (because I have a couple) with an eye to future replacement with 1627SE when budget permits.
--Sherman
Old 3rd November 2004, 10:59 AM   #25
Cassiel is offline Cassiel  Libya
Same question: what output transformers do you recommend?
Old 4th November 2004, 09:30 AM   #26
Mine are custom from sowter. But a hammond should work. The tubes are biased at 75mA so any 5k (or maybe 3,5k) transformer that can handle the bias-current should work. I think 2,5k might be a little low but you get double the output power. The 125ESE should work really well for testing, but personally I would get the 1628SE.
Old 5th November 2004, 03:27 PM   #27
...a hammond should work....2,5k might be a little low but you get double the output power....
I'll give the 125ESEs a chance for testing then. What do you estimate the power output of your amp to be?
--Sherman
Old 5th November 2004, 07:29 PM   #28
Kashmire is offline Kashmire  United States
I'm sold on Plitron, but they are costly.
For my next SE project, I'm looking at One Electron. They are about the same price as Hammond.
There's another thread on James transformers, which look very interesting...
However, my final SE amp will use Plitron, because I think they are the best.
Old 6th November 2004, 09:07 AM   #29
I get somewhere between 4-5W from my amp.
Old 6th November 2004, 03:15 PM   #30
Excellent output. My "main" speakers are 93-94db/W/1M so they should be a decent match. This is looking better and better!
I've started to put together my parts list (and comparing it to what is in the parts bin). I am looking forward to this project.
I was checking out various KT88 tubes and saw the one with blue glass at Antique Electrical Supply. Hmmm... very pretty, high WAF for putting the amps on display!
--Sherman
SE  KT88 AmpHide this!Advertise here!
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 01:26 PM
Help - CFB in a KT88 SE amp Drewaudio Tubes / Valves 4 30th January 2007 05:36 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 09:19 AM
Drd Kt88? hacknet Tubes / Valves 13 26th August 2004 04:41 PM
Would it be possible? OTL/OCL KT88? Layberinthius Tubes / Valves 4 25th January 2004 12:31 AM
