diyAudio Sponsor
Old 30th September 2004, 07:00 AM   #1
Default nuvistor MC step up
Hello tubies,
can anyone help with information on nuvistor MC step up amplifier. As I know Conrad Johnson has made such things in the past. What about noise? Is the nuvistor a good part for that application?
Reinhard
Old 30th September 2004, 11:37 AM   #2
SY's Avatar
Difficult to find, expensive, and really microphonic. Oh, yeah, and not super quiet.
A better choice is something like a 417A.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 30th September 2004, 12:39 PM   #3
Geek's Avatar
Try four paralleled (8 sections) 12AX7WB's
Old 30th September 2004, 01:22 PM   #4
jlsem is offline jlsem  United States
jlsem's Avatar
A pair of cascaded 8056 nuvistors with battery B+ can provide a very quiet MC phono pre-amp. Has anyone ever tried battery coupling? I've always thought this tube is a good candidate.
John
Old 30th September 2004, 01:23 PM   #5
Default 8 paralled section of 12 AX 7
Hello,
think that is what Aesthetix is doing. Is that really low noise or should I go for 6C45 or 437?
Reinhard
What can I do with my 40/40 pcs. of 2C51/2C52?
Old 30th September 2004, 01:26 PM   #6
Default cascaded
Hello,
what do you mean with cascaded? SRPP, u-follower, cascode
or two stages?
Reinhard
Old 30th September 2004, 01:31 PM   #7
jlsem's Avatar
Two stages; the 8056 has a mu of 11 but can be operated very linearly with 12-24 vdc on the plate.
John
Old 30th September 2004, 01:36 PM   #8
analog_sa's Avatar
Don't know about the noise but a 6S45 will absolutely kill paralleled 12AX7 soundwise. IN any case the noise will be very dependent upon PS noise.
Old 30th September 2004, 01:45 PM   #9
diyAudio Senior Member
fdegrove's Avatar
If the datasheet is anything to go by req is ~100R which is extremely low.
If the curves are linear at Vg0 you can ground the cathode and couple the tube straight to the cartridge, one less cap in the signal path.
Otherwise it's an amazingly good tube for low level signal applications. Certainly one to consider for anything phono.
// 12AX7s is about the last thing you'd do for an MC stage IMHO.
Another candidate is the 6DJ8 which is what I used prior to the availability of the USSR special tubes.
Frank
Old 30th September 2004, 01:48 PM   #10
SY's Avatar
As a rule, voltage noise runs about 2.5/gm. It takes a lot of 12AX7 sections to equal a proper high transconductance triode.
5718 Nuvistor ? exurbia Tubes / Valves 4 1st June 2009 04:16 PM
nuvistor bias with 18V ? space-cake Tubes / Valves 13 27th February 2007 08:05 PM
Is the Nuvistor Better Than The 12B4 For A Line Stage Mark A. Gulbrandsen Tubes / Valves 18 19th August 2006 11:21 AM
7586 nuvistor mr l Tubes / Valves 15 7th January 2006 07:17 AM
nuvistors & nuvistor sockets fermatsEnigma Swap Meet 0 31st July 2005 08:47 PM
Page generated in 0.12511 seconds (75.51% PHP - 24.49% MySQL) with 11 queries
