nuvistor MC step up - Page 3 - diyAudio
Old 4th October 2004, 03:59 AM   #21
SY's Avatar
A FET is just a pentode without the partition noise.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th October 2004, 08:00 AM   #22
diyAudio Senior Member
fdegrove's Avatar
Not so sure we'd all agree on that...
If you'd were to say: a cascode instead of a FET then, yes. Sort of.
While both cascode and penthodes sport very high gain, you're still stuck with the fact that they're not the most linear devices either.
Which is probably where the SLCF comes in, to kill a few birds with one stone. So to speak.
(just ignore the line stage bit)
I wouldn't do that. If it's for the sake of showing the frontend of an MC capable phonostage, O.K.
However if you'd want to build it I'd recommend adding the SLCF or another buffer.
Since the RIAA type used is of the split, fully passive type, you just can't leave the last stage open ended; it requires a defined g' to work against.
Frank
Old 6th October 2004, 07:18 PM   #23
Default More schematics
Hello,
donīt know what to do. Are there more schematics,
Conrad johnson, Audio research?
Reinhard
Old 7th October 2004, 06:42 PM   #24
Hi
Here you will find the Conrad Johnson Premier Six head amp and a lot of other things: http://www.pi.infn.it/~federico/further.htm
I have a Music Reference RM4 head amp schematic somewhere. It uses parallelled 6DJ8 halves (one Tube per channel). I can try to find it if anybody is interested.
Torben
Old 9th October 2004, 09:19 AM   #25
Default mc step up
Hallo,
thank you hermann,
can anybody help with schematics of Aesthtix I/O or Rhea?
Reinhard
Old 9th October 2004, 04:53 PM   #26
Yugo's Avatar
Default Head amp!
Originally posted by Herrmann
Hi
Torben
Herrman,
Would you be so kind to post sch. of MR's RM4 head amp?
Yugovitz
Bird lives!
Old 9th October 2004, 05:38 PM   #27
analog_sa's Avatar
Default rm4
Yawn...
Old 9th October 2004, 05:57 PM   #28
Yugo's Avatar
Default Re: rm4
Originally posted by analog_sa
Yawn...
Thanks,analog_sa!
Yugovitz
Bird lives!
Old 17th December 2005, 05:46 PM   #29
Hello,
are there more step upīs out there, what about Bob Carverīs
Sunfire solution
Reinhard
Old 17th December 2005, 11:19 PM   #30
Brian Beck's Avatar
Default Caution on direct coupling grid to MC
If the curves are linear at Vg0 you can ground the cathode and couple the tube straight to the cartridge, one less cap in the signal path.
I've played with high transconductance tubes at low Vgk for MC use. The grid current becomes a real problem if you direct couple to the MC. If you calculate the tiny signal currents that an MC makes, this grid current is a huge relative DC bias on the MC coils. For example, an MC which makes 0.5mV at 5cm/s (a very high musical level, nevermind at -90dB below this level) will deliver 5 microamps rms into a 100 ohm load. Grid current for a 6C45/6S45 at small negative grid bias can approach this value. Better to run larger negative Vgk which means (for the same Ia) higher Va, and unfortunately higher Pa. But much lower grid current.
Brian
Is the Nuvistor Better Than The 12B4 For A Line Stage Mark A. Gulbrandsen Tubes / Valves 23 22nd October 2013 03:56 PM
5718 Nuvistor ? exurbia Tubes / Valves 4 1st June 2009 04:16 PM
nuvistor bias with 18V ? space-cake Tubes / Valves 13 27th February 2007 08:05 PM
7586 nuvistor mr l Tubes / Valves 15 7th January 2006 07:17 AM
nuvistors & nuvistor sockets fermatsEnigma Swap Meet 0 31st July 2005 08:47 PM
Copyright Đ1999-2017 diyAudio
