nuvistor MC step up - Page 2 - diyAudio
Old 30th September 2004, 02:13 PM   #11
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I'm told someone used 6HS5! Mu = 300, gm = 65mA/V. You need >400V on the anode before it wakes up. Oh, and it's a power valve with a duodecar base and 1.5A heater (6.3V, though).
6C45 is probably the best bet...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th September 2004, 02:20 PM   #12
Geek's Avatar
Originally posted by fdegrove
Another candidate is the 6DJ8 which is what I used prior to the availability of the USSR special tubes.
Yeah! That's the one I meant
(read it in a TubeCAD article)
Old 30th September 2004, 04:05 PM   #13
SY's Avatar
I've got a vision of a 6528A-based head amp. Cascode, of course, just because of the low mu.
It is not a pretty vision.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th September 2004, 04:14 PM   #14
diyAudio Senior Member
fdegrove's Avatar
Yeah SY....
Go head and promote the 6528A.....
Then complain when it's become absolutely unobtainable....or worse: only Chinese ones....Yikes.
It's not as if you'd need them, right??
Frank
Old 1st October 2004, 05:15 PM   #15
Default mc step up
Hello,
everytzhing is interesting to me,
can anyone post schematics of analog stage and if possible powersupply.
Reinhard
Old 1st October 2004, 05:53 PM   #16
Default Re: mc step up
Originally posted by reinhard
Hello,
Reinhard
If you haven't already got it, the Counterpoint SA2 MC head-amp and psu schematic is on the Altavista Audio website.
Old 1st October 2004, 07:12 PM   #17
I owned a Conrad Johnson HV1-A at one point and can say that it sounded just marvelous. However, I can also confirm that it was microphonic as hell. Off the top of my head, I can't recall which tube they were using. The circuit was a simple grounded cathode as I recall. I drew it out before letting the unit go, but have no idea where the schematic got to--this was years ago, and I've moved a couple of times in addition to the usual number of other things that disarrange notes. If I get time, I'll try and scratch it up, but it'll be a day or two...or three.
Just beware of the microphony. They had the circuit board mounted on an "elastomer" suspension, meaning that they looped rubber bands through holes in the corners of the board and laced them around standoffs mounted an inch or two away. Still rang like a bell (lovely tinkling noise) if you rapped the chassis with your knuckle. Don't say you weren't warned.
Grey
Old 2nd October 2004, 08:09 AM   #18
Default Thanx
Thank you rfbwr for the tip with Altavistaaudio, will have a close look.
Thank you Grey for searching, hope you can find it.
Have a happy weekend,
Reinhard
soldering irons warm?
Old 2nd October 2004, 07:39 PM   #19
frugal-phile(tm)
planet10's Avatar
this is a well regarded phono that works with MC... you can use a triode on the bottom of the cascode, but it isn't as quiet. (just ignore the line stage bit)
(from Vacuum State web site)
If you just want to step up the signal for an existing you could probably adapt the 1st stage, but it might make sense to do the whole thing.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th October 2004, 02:25 AM   #20
fdegrove's Avatar
Default Strictly Tubes...almost.
Maybe not but I can't help but wonder what this circuit would sound like with a really high gm tube such as the 6C45-P replacing the frontend....
With a Req 100R it has all the potential to come close to the 2SK170BL as far as noise goes, besides tube noise is far less obtrusive to my ears_if at all audible_ than semi-conductor noise.
Then of course there's always MC HAMMER if you're looking for an add-on headamp.
It's dead quiet, can take just about any MC, uses ordinary parts, looks deceptively simple and does not have the word "microphony" in its vocabulary....
All it needs to shine are two pairs of tightly selected 6922s, two matched low noise CCSs and you're done.
Frank
Is the Nuvistor Better Than The 12B4 For A Line Stage Mark A. Gulbrandsen Tubes / Valves 23 22nd October 2013 03:56 PM
5718 Nuvistor ? exurbia Tubes / Valves 4 1st June 2009 04:16 PM
nuvistor bias with 18V ? space-cake Tubes / Valves 13 27th February 2007 08:05 PM
7586 nuvistor mr l Tubes / Valves 15 7th January 2006 07:17 AM
nuvistors & nuvistor sockets fermatsEnigma Swap Meet 0 31st July 2005 08:47 PM
Copyright 1999-2017 diyAudio
