I've just found some 6aq5 tubes lying around, and looking at the gain of these things they have just about the right gain in triode mode for a (much needed) line stage. They should also have more than enough grunt
Problem is, i have no experience designing tube circuits, and this is far from the normal application for these things. I've searched everywhere but can't find a thing. If anyone could help me out with component values, i'd be most appreciative Thanks, Hamish |
#2 |
What do you have available for a PS, and at what voltage? That'll be your starting point to determine what you can easily use for the B+, unless you're willing to get something made (muchos pesos in Oz) or use surplus.
It's unlikely many people have used this tube in this application, but I can't see why it won't sound good. Trouble is, you're going to have to find the op point yourself (which is why I asked about the PS). An OTTOMH suggestion to start would be B+ = 400V, Ik = 30mA, Va = 150V, Rl = 8k (20W), or 300V B+ / 5k. |
#3 |
Thanks for the reply, Brett. I've been meaning to build your 12B4A line stage but got side tracked with silicon
It's good to get a little validation on the design. Seeing noone had used it before had me worried, but you've gotta try everything at least once (except folk dancing). As for power, i've got a 250-0-250 little transformer (rather poor quality) that was in the AWA receiver that i got the tubes from. I also have a 350-0-350 R-core moster i bought a while back for the 12B4A that never was.......yet. I figure if i can get this working with some junk stuff, then i can splash out a bit more on some real hardware. Thanks again, Hamish |
#4 | ||||
Measure the transformer secondaries and futz with the numbers to see what you get. Even with the big one, and a couple of RC stages the 300V op point I mentioned is viable, if you don't mind a few extra watts of heat. Quote:
#5 |
Thanks for your replies. I've modelled a few in PSUDesigner, and for now trying to get an CRCRC filter to work with R values of a sensible wattage. I want to try and use the cheap transformer, as i have the big one still planned for the 12B4A. I see Evatco have some reasonable open style chokes for around $30 a piece.
I'm just working my way through a tube design book now, so hopefully i'll be not so much in the dark. I found the sticky thread for newbies, so i'm devouring everything in there for now. I do have to admit the 6AQ5's 8% THD is a little disturbing.....but this is a first project ![]() Thanks again for your help and guidance, Brett ![]() Cheers. |
#6 | |||
The open frame Hammonds are quite good, and the 193's good for poweramps. As I mentioned in the last post, you can build this using the bigger trans, and with a 4 resistor modification and some new sockets, use the 12B4A's later in the same setup. Just don't build it all fancy until you finalise it Quote:
#7 |
frugal-phile(tm)
The 6AQ5 is similar to the 6BQ5/EL84 which i have seen mentioned for use in triode mode in a line stage.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | |
John |
#9 |
I actually wanted to try and avoid using an output transformer, and just go with a cap. I've found a couple of schematics using similar tubes in triode mode for headphone output (also some for the 6BQ5 (thanks for the tip, Dave), which i seem to remember are lurking inside my Akai R2R
#10 | ||
| Which DHT for Line stage? | andyjevans | Tubes / Valves | 15 | 26th March 2009 01:10 PM |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| #26 line stage help | Original Burnedfingers | Tubes / Valves | 4 | 9th July 2004 10:56 AM |
| Line stage | woody | Tubes / Valves | 5 | 10th August 2003 08:55 PM |
