Any experience with this nice toroidal OT? - diyAudio
Old 28th September 2004, 03:43 PM   #1
jogas is offline jogas  Italy
Default Any experience with this nice toroidal OT?
HI,
I found on the internet the amplimo site and among the many available transfo I found this interesting one
http://www.amplimo.nl/download/3a524.pdf
It is unexpensive but it is the less performant of the whole available pool.
Does anybody have experience or suggestions?
Are the bandwitdth values "enough"?
Thanks in advance
Giuseppe
Old 28th September 2004, 04:12 PM   #2
Frank Berry's Avatar
Others may disagree with me but I don't think the specs are very good.
I'm concerned with the frequency response which was measured at a power level of 1 mW.
The primary capacitance is 1.79 nF. That's a lot of capacitance. I'm also concerned that the -3dB power bandwidth (assuming 40 watts) only goes down to 27 Hz. If the output is down 3dB at 27 Hz, the transformer won't have a really good low frequency response below about 60 Hz.
Also ... look at the phase shift at 20 kHz. It's almost -60 degrees.
I'd pass on this one. I'd like to hear what others have to say.
Frank
Old 29th September 2004, 02:56 PM   #3
igormak is offline igormak  Russian Federation
igormak's Avatar
I did not try exactly this OT, but I ordered and tested Plitron
PAT4002. Both from Vander Veen, anyway. Sure the same
iron. Results was very bad, you'll nothing hear below 200Hz at all. High frqs very good >200kGz. Sounds very bad and durty.
I broke one "famous" OT. The reason in Economy. Economy of Fe and Cu.
Igor.
Old 29th September 2004, 03:04 PM   #4
Thanks for your answers.
Surfing the web I found this other trasfo that shoeul be much better...
http://www.shinrock.com/Audio_Transf...4.3k_0.95.html
what do you think about it?
Old 29th September 2004, 06:38 PM   #5
frugal-phile(tm)
planet10's Avatar
PAT4002.
The Amplio OPTS & the Plitrons are the same, made by Plitron, designed by Meeno van der Veen.
I was lucky to sit in on a hearty discussion between Meeno & Bill Perkins (PEARL) about the merits of these. Bill was championing C-Cores. A lot of what was discussed was over my head, but both these guys know A LOT about transformers.
The big issue with the toroids is that they can't handle DC very well, and invariably in an OPT (unless parafeed) you will have DC.
Personally if i had serious money to spend i'd be looking at the Lundahls.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th September 2004, 08:27 AM   #6
igormak's Avatar
dave
Hi Dave,
Yes, tors likes DC less than EI do. They have other advantages anyway. Here is the skill of engineer how to use tors.
With correct winding and right core problem decisionable.
Simply, Plitron doesn't count their OT properly. VanderVeen answered me on my letter with "your output stage not right balanced". So, they use DC as just a gost.
Now I wind tors only myself and think real DIYer have to do it himself. It's not too complicated really, IMO.
Igor.
FS Nice heavy Toroidal Power Transformer Bamalama Swap Meet 2 17th February 2009 03:10 AM
NICE; Custom 250VA Toroidal Power Transformers; 34vac/7a, plus an Auxiliary Winding dozer Swap Meet 0 19th January 2009 10:10 AM
Opinions/Experience of Toroidal valve amps balancesingh Tubes / Valves 65 4th April 2008 01:30 AM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 04:41 AM
Nice HS for GC Praudio Swap Meet 1 17th September 2003 01:40 PM
Copyright 1999-2017 diyAudio
