A good SE project?
I have been listening to several tubeamps the last week. OTL, p-p EL34 and p-p EL84. To my speakers (Bastani Prometheus) the Edison 24 (with EL84 tubes) was a good match. I'm thinking of building a good SE amp, and wondered if the EL84 also will make a good job in such a construction? There are maybe other tubes that will work even better? I need like 2-3 watt I guess. I would like to get some input on a good projects to work on during the winter. Appriciate som nice suggestions.
Bjørn
Konnichiwa,
Used as pentode the EL84 requires negative feedback on your speakers, but you can get between 3 - 4 Watt. If you use the EL84 as triode (it makes a very nice sounding Triode) you are down to 1.5 Watt or 2 Watts at best.
The way around this would be a EL84^3/5 design, using one EL84 as driver and two or four triode connected EL84 in parallel into 2K4/1K2 output transformers for around 4 or 8 Watt theoretically.
Sayonara
