Old 25th September 2004, 12:07 PM   #1
adalin is offline adalin  Sweden
adalin's Avatar
Default 6d22s
Hi
I am currently planing the design on a tubeamp and got a problem with what kind of recifier I will use.
I have some 6D22S tubes that I want to use but I dont know how much uF I can use whit them?
I have searched everywere but cant find the data.
I have heard that they are qite robust?
I will use a 10H chocke in the power suply so how much uF can I put before and after the choke
please help?
Tubes 4 ever
Old 25th September 2004, 12:25 PM   #2
sonix is offline sonix  Germany
here is an example.
Old 25th September 2004, 01:34 PM   #3
Geek's Avatar
With a valve rectifier, it's standard to use between 10 and 40uF before the choke. Any capacitance after the choke can be much larger (I have used 5,000uF with no tube damage) if their is a proper bleeder to maintain critical choke current.
Old 26th September 2004, 09:36 AM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
I have used 2x 100uF in series (=50uF) with no problems. This is the value used in examples at the Svetlana site.
Old 26th September 2004, 02:26 PM   #5
adalin's Avatar
Ok
I will probably try with like 32uF before the chocke and 470uF after
Tubes 4 ever
6S33S & 6D22S for sale Vladi59 Swap Meet 0 22nd December 2008 03:04 PM
6D22S Getter Question Ardee Tubes / Valves 5 27th September 2006 09:35 AM
How to use Svetlana 6d22s? protos Tubes / Valves 3 3rd February 2006 03:51 AM
6D22S Damper Tubes Peter Menting Tubes / Valves 15 27th March 2004 02:57 PM
6d22s GAK Tubes / Valves 10 2nd September 2003 02:04 PM
Page generated in 0.07575 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
