diyAudio Sponsor
Old 23rd September 2004, 05:48 AM   #1
emil_86 is offline emil_86  Austria
Post beginners ecl82 power supply
Hy!
Im going to build my second tube amplifier !!
But there's one problem :
I'm using this circuit (http://nmwilliam.tripod.com/ecl82.html) but
i have bought a power supply with ez80 tube that is supporting 247V !!
What Resistor i have to use to set the voltage down ??
Is it enough when i take 4 x 62kohm with 0,6W ??
Should i use capacitors ??
Thanks !!
Old 23rd September 2004, 08:05 AM   #2
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Emil,
Im not sure the answer to your question, but isnt it better to use a tube rectifier so as you dont get turn on thumps?
cheers luke
Old 23rd September 2004, 08:41 AM   #3
Yvesm is online now Yvesm  France
Yvesm's Avatar
Default Re: beginners ecl82 power supply
Originally posted by emil_86
Hy!
Could you post the schema of your Power supply ?
Yves.
Old 23rd September 2004, 08:56 AM   #4
frugal-phile(tm)
planet10's Avatar
There is a thread here on Morse's 6BM9 amp with a power supply voltage much closer to yours.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd September 2004, 09:45 AM   #5
Here is it ! but i have messure the voltage and it is 247 Volt!!!
Old 23rd September 2004, 12:44 PM   #6
Yvesm's Avatar
I don't doubt !
Wanted to have a look at the schemo before making any suggestion !
I can't see it here, is it the one drawn in the referenced link ?
Anyway, do you measure voltage with or without load ?
Each amp will probably consume some 30 to 40 mA.
Nevertheless, there is no risk to try, at least for few minutes, the time to take voltage while working.
Yves.
Old 23rd September 2004, 03:46 PM   #7
emil,
i built the same project, and my power supply is almost 300v.
I have tried using 240v (two identical transformer back to back) I didnt like the 'thin' sound i get. so i think yours is just fine.
If you really want to lower it, 1.5k resistor 25w to replace the (100R 5w) should do the trick.
But i think within <250v is fine. It runs hotter but it sounds richer
Old 23rd September 2004, 04:46 PM   #8
frugal-phile(tm)
planet10's Avatar
Morse's 6BM8/ECL82 thread
No bang, no flash, just music!
His has 240 V at the OPT
dave
Old 24th September 2004, 03:00 AM   #9
I have some of these valves and wondering if I should build it with valve rectifier or diode? Doesnt the valve rectifier have no turn on thumps?
cheers luke
Old 24th September 2004, 03:07 AM   #10
diyAudio Senior Member
fdegrove's Avatar
Do other rectifiers cause turn-on thumps???
How about a pair of each....?
Seriously, it's not the rectifiers that cause turn-on thumps...
Frank
Chip amp power supply- a beginners guide Nuuk Chip Amps 702 20th May 2012 05:48 PM
ECL82 power supply question chrish Tubes / Valves 26 18th February 2008 10:07 PM
Page generated in 0.11194 seconds (80.56% PHP - 19.44% MySQL) with 11 queries
