This is a Cleo V and Phono Dude in one. Which would you choose?
(click on the link for the examples)
The 4 nine pin sockets in a group is the phono amp section.
The big sockets are for Ba tubes..
Cheers and thanks in advance,
Bas
http://basenjes.de/photoalbum/altjo/index.html
Bas
Well I am old fashioned. And so is the buddy I'm building it for.All are too traditional.
I could also have tried something like the minimal reactance PSU ...as coined and thought up by Dave Davenport of Raleighaudio. But the request was to build a Cleo V and Phono Dude.
What specifically would you suggest?
Bas
Bas
I would go for something more radical. Something along the lines of the Fi amps.
Aah yes...I like that design as well...that is what I call thinking outside the box..
Take the F, rotate output section (two 9-pin sockets and two big ones) 90 degrees clockwise, then turn the entire device 90 degrees clockwise and that'll be my choice
Hi TG,
That is an excellent suggestion...Never thought of that...but probably won't do that because all the RCA plugs etc, would be to the right of the amp...depends on the future owner of the amp..
Thanks again...
Bas
You're welcomeThat is an excellent suggestion
Yes, and that's also my choice . Just hate to crawl behind the amps connecting something...but probably won't do that because all the RCA plugs etc, would be to the right of the amp
Undoubtedly.depends on the future owner of the amp
Good luck to you and your amp,
Alex
B is a looker..but the phono section to the right...will have looong wires from the rca plugs...all the way between the psu trannies and chokes...and all thatB is where its at
LOUD BUZZER....wrong option..Thanks for trying though Brett
How much harm can a little extra wire make
Not much...I agree..but the path is important I think...phono is a small signal...and in that sense susceptible to all kinds of rfi/emiHow much harm can a little extra wire make
Yep I agree, sorry was being cheeky. But I quite like the traditional tube amp layouts with wood copper etc.
I think yours will look real nice
Wire
Hi Bas, If you use the right wire, you'll not notice anything.
BTW. I have the right wire for this section
It's not cheap, but the best one I've ever used.
Best regards,
Audiofanatic
Best regards,
Audiofanatic
What kind of wire is it?BTW. I have the right wire for this section
100% sheelded twisted pair wire!
Silver plated Mil specs wire!
You can see it when you pickup the ESL's
Just let me know when you'll be able to pick them up.
Audiofanatic
Audiofanatic
- Tubes / Valves
- Please cast your votes..or make a suggestion or 2
