choke value
choke value
Old 15th September 2004, 11:28 AM   #1
Sandor is offline Sandor  Italy
Default choke value
How to choose the correct value of the inductance for a choke loading anode in an common cathode stage? I suppose that this depends on Rp of the tube and on the desired frequency lower bound, but
HOW CAN I PRECISELY CALCULATE THE REQUIRED INDUCTANCE FOR THE CHOKE LOAD? Best regards.
Paul
Old 15th September 2004, 12:47 PM   #2
Geek is offline Geek
Geek's Avatar
Optimally (is that a word?), XL=(4*RL) at the lowest frequency you want to amplify.
Most designs use between 100 and 300H.
Old 15th September 2004, 05:32 PM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
For -3dBV at F, L is EXACTLY (as you requested)
(Rp+RL) * 2 * pi * F / Rp * RL
For your purposes, pi = 3.1415926535897932384626433832795.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 15th September 2004, 05:39 PM   #4
Fuling is offline Fuling  Sweden
Tim, please tell us where you get chokes with such low tolerances
Old 15th September 2004, 07:35 PM   #5
Sch3mat1c's Avatar
Default Re: choke value
I sincerely wish I knew.
Tim
Old 15th September 2004, 10:03 PM   #6
I know, I just couldnīt keep my mouth shut.
Sorry for that.
Back to the topic:
Ive seen XL=2Rp somewhere, but that might be a bit low
Old 15th September 2004, 10:12 PM   #7
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Excel sheet..
dunno where I got it from...
If you can see the speaker cone move...it's not hifi.
Old 16th September 2004, 11:24 AM   #8
Yugo is offline Yugo
Yugo's Avatar
Default Re: Excel sheet..
Try this:
www.vt52.com -- DIY Corner - Tips & Tricks - software tools
Yugovitz
Bird lives!
Old 16th September 2004, 11:24 PM   #9
Thank you all!
Bas: great tool!
Yougo: nice site indeed!
Paul
choke valueHide this!Advertise here!
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 05:43 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 09:30 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 12:05 PM
L as a choke. bogdan_borko Solid State 9 9th September 2006 10:48 PM
SS PSU without choke Mikael Abdellah Tubes / Valves 29 15th January 2003 05:34 PM
