Inductors made for crossover in an amp?
Old 15th September 2004, 04:16 PM   #11
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
My Coil Design and Construction Manual, by Babani Electronics Books, shows no equations, but tables for different contructions. Basically, you select an inductance from a list of common values, or from a nomograph to find other decimal values, then apply corrections to apply this data to a core of your choice (the ratios of data in the first table assumes one particular core). The assumption is made that you use a wire suitable for the current capacity, and the tables find a turns number which just happens to fill out the core. There are also tables for proper air gap, which the data assumes you use.
But that doesn't help you any, so I'll add: L = 3.2 * N^2 * mu * A * 10^-8 / l, where L is in henries, N is turns, mu is permeability, A is cross-sectional area of the core (center leg) in square inches and l is length of the magnetic path in inches. For generic transformer iron, mu = 1000 or so (up to 100,000 for mu metal).
RDH4 has a lot of info on the subject.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 16th September 2004, 02:25 AM   #12
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Tim,
I have checked local bookstores but no book like that here.
Thanks for the equation btw. I am so interested in choke making that if you have additional data about them please send me a copy at jojod818@yahoo.com
Thanks!
JojoD
Old 16th September 2004, 11:28 AM   #13
Yugo is offline Yugo
Yugo's Avatar
Default info fo PSU chokes
[QUOTE]Originally posted by JojoD818
[B]Just curious, why can't I find any details on winding a diy choke? I mean, we have the magnet wires, the E-I cores, covers and legs, the only thing missing is the number of turns and what size to use.
Jojo,
Radiotron Designer's Handbook is an excellent source for info regarding chokes and PSU.I wind my chokes using Hanna's method which is well described,and is in a way, empirical method,mostly.Just convert the values in metric numbers(if you need) and use the little graph for determing the gap,turns,etc....Haven't had any problems so far!
Yugovitz
Bird lives!
Old 16th September 2004, 04:01 PM   #14
JojoD818's Avatar
Thanks!
Now I have to look for that handbook.
Inductors made for crossover in an amp?Hide this!Advertise here!
Trade your crossover parts. Capacitors, inductors and resistors. owdi Swap Meet 0 21st August 2007 10:27 PM
Switching position of crossover inductors. Jay Multi-Way 0 8th August 2005 01:25 AM
Need help in desigining crossover inductors venki Multi-Way 5 14th June 2005 04:44 PM
can this crossover by made bi-ampable? cowanrg Multi-Way 3 28th August 2003 09:06 PM
impedence with self made crossover trespasser_guy Multi-Way 2 19th September 2002 12:39 AM
Copyright ©1999-2017 diyAudio
