diyAudio Sponsor
Old 11th September 2004, 04:04 AM   #1
Geek's Avatar
Default Microphone preamp with compressor
I'm staring a new thread here to minimize the off-topic chit-chat from the 12AX7 thread. What we were talking about is here:
http://geek.scorpiorising.ca/MicPreamp.html
Now, to answer specific questions about it
Originally posted by JojoD818
Geek,
I also saw that you have a mic preamp with a compressor (separate schematic) and wowow! Have you actually tried using it? Can you describe how it sounds?
Yes. Go to http://www.scorpiorising.ca/music.shtml and all the ones I did with lyrics, used this mic preamp.
Seems that all the parts are locally available here except for the LED/LDR part. Maybe I can just build a discrete LDR/LED for such use?
JojoD
Newark Electronics was the only place I found the devices known as "vactrol's". They cost me $8 CAD each about two years back.
You can, with equal performance, use a bright (I use 3,000 mcd) LED and a LDR (I used a 3.5k to 50M) face-to-face inside a short piece of drinking straw, seal the ends with auto silicone sealer, then cover the whole gadget in heat shrink tubing. The key to success with this method is use of a fast LDR - 50mS decay max.
Old 11th September 2004, 04:19 AM   #2
Optical is offline Optical  New Zealand
hmm, so is this solid state or tube stage compression? or a combo? is any audio signal going through the solid state section is what i mean..
also is the LM3900 choosen for a particular reason? it seems to be discontinued.. i notice its specifically for running from one rail, so would an LM324 work? (lm324, have i got that right??)
oh, and my last question, can the 12AX7 be substituted straight in? i have a bunch lying around and dont like my chnaces of finding a 6N1P
Old 11th September 2004, 04:24 AM   #3
TobWen is offline TobWen  Germany
@Optical: it is a tube stage ... or can you see any solid-state-chips in the preamp-schematics? :-)
@Geek:
So you mean, I can simply connect the microphone with +48V (via http://www.diyaudio.com/forums/attac...&postid=472164) to your preamp without damaging anything?
Old 11th September 2004, 04:25 AM   #4
Geek's Avatar
As with all my audio projects, the signal line never sees silicon
The 3900 is still in full production by National.
I chose the 3900 over the 324 for the reason it's a current (Norton) amp and therefore inherently a high impedance device. Perfect for interfacing with tubes! A 324 in this circuit does strange things. I am going to R&D a 324 version because while the 3900 is still in production, wholesale lots of less than 1,000 chips are getting harder to find.
Old 11th September 2004, 04:28 AM   #5
Geek's Avatar
Originally posted by TobWen
@Geek:
Yes, that is correct. I forgot to show in the diagram, the capacitor (DC blocked side) goes to the mic preamp. Putting DC on any preamp input (SS or tube) can damage it.
The 10K resistors limit the current to a level that will not damage the microphone if it is wired incorrectly.
Old 11th September 2004, 04:35 AM   #6
JojoD818's Avatar
Default Re: Microphone preamp with compressor
My thoughts exactly! I already used one before on a sub compressor/limiter circuit and seems the discrete LDR/LED combo is functioning well.
Thanks Geek for a wonderful tube circuit collection!
JojoD
Old 11th September 2004, 04:37 AM   #7
Would it be bad to put it on a PCB ?
Old 11th September 2004, 04:45 AM   #8
Geek's Avatar
Nope, not at all! It just doesn't look as sexy then
Old 11th September 2004, 04:55 AM   #9
at the moment sound is more important for me than design.
What do you think about this beast:
http://www.siliconchip.com.au/cms/A_30804/article.html
If link does not work (redirected to paysite), try to visit the site via Google :-)
But now tell me ... where in Europe can I buy two 6N2P?
I think, two 6N2Ps are needed, correct?
Old 11th September 2004, 05:31 AM   #10
Geek's Avatar
I have not heard that amp, nor heard of someone who did, so I can offer no opinion as to it's performance Sure is cute though
The 6N1P and 6N2P I get straight from a broker/friend in Lithuania, so I can't say of shops. I do know www.evita.lt in Vilnius Lithuania as well as KW Tubes in Russia sell them. Evita is priced well though (prices are in Lita's, not USD like KW)
PS for microphone preamp kubeek Power Supplies 3 28th April 2008 05:55 AM
Compressor for preamp impsick Chip Amps 4 24th March 2007 04:58 PM
usb or pci microphone preamp biovizier Solid State 0 27th February 2006 09:21 AM
microphone preamp svokke Tubes / Valves 18 3rd December 2005 01:01 AM
6C45Pi Microphone Preamp MIKET Tubes / Valves 4 2nd May 2004 12:08 AM
Page generated in 0.11151 seconds (81.48% PHP - 18.52% MySQL) with 10 queries
