12AX7 sound ... going with the trend
Old 9th September 2004, 08:37 AM   #11
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Originally posted by Geek
"Starved plate" is a great way for fuzz, but also adding noise. Would you run a transistor thingy in your stereo line with 1 volt on the Vcc? 45Va is basically the same thing.
IMO, if you need line-level amplification, dump the 12AX7 and think 12AU7, 12AT7, 6DJ8 or my favorite, the Russian 6N1P
I agree with your comments, I am just explaining why the guys who designed that circuit used +45V, I mean they intentionally did that to starve the tubes.
I also love the russian 6N1P, have lot's of them coz they come in relatively cheap here locally.
Any circuit you have for 6N1P tubes you wanna share?
Old 9th September 2004, 09:46 AM   #12
Geek is offline Geek
Geek's Avatar
I use them mainly in White-CF or mu stages, as they seem to be ideally suited to that
Here's a linedriver mu-stage I made for my Akai AT-2400 tuner:
http://www3.telus.net/small_business/Geek/TunerOut.png
My microphone preamp contains the same output, but in a White-CF:
http://www3.telus.net/small_business...reampFINAL.png
Can you tell me / show me the circuit of a solution, based on 12AU7, 12AT7, 6DJ8?
Watch the link of the MIC100/MIC200 I've posted at the start of this threat. As you can see, the chassis is VERY small.
Y'know, I re-read your original post and Fred's McTube is a good little box. Pop an 'AT7 in it and she goes from "warm" to "crystal"
You can also try a mu stage based on the 6DJ8. Check the link I posted for Jojo, reduce the Va from 250 to 120 and you'll be OK.
Old 9th September 2004, 09:51 AM   #13
Geek's Avatar
Oh, forgot to mention, the 12AT7 is also a good White-CF:
http://www3.telus.net/small_business...7-White-CF.png
Slightly less "grumba" since the cathode of the 'AT7 is teeny-tiny compared to 6N1P. But it has a beautiful, mellow quality that is unique. If I were building a linedriver for a person who loved Blues/Jazz, I'd make them a 12AT7 CF or mu.
One caveat with an 'AT7 - they loooooove to motorboat. Decouple the power supply line good!
Old 9th September 2004, 02:29 PM   #14
JojoD818's Avatar
Thanks for the circuits! Now My 6N1Ps will have some use. I like the microphone preamp too.
JojoD
Old 9th September 2004, 04:32 PM   #15
TobWen is offline TobWen  Germany
I've got a +48V PSU & mic ... what do I need to modify that is accepts the voltage on the grid?
Edit:
I also have found a very interesting project ... but it uses amplification:
http://www.siliconchip.com.au/cms/A_30804/article.html
Old 9th September 2004, 10:13 PM   #16
Geek's Avatar
Just add a DC blocking cap. Performence degredation is minimal.
Edit:
Cute! I like it
Old 10th September 2004, 03:22 AM   #17
JojoD818's Avatar
Geek,
I also saw that you have a mic preamp with a compressor (separate schematic) and wowow! Have you actually tried using it? Can you describe how it sounds? Seems that all the parts are locally available here except for the LED/LDR part. Maybe I can just build a discrete LDR/LED for such use?
JojoD
Old 10th September 2004, 06:07 AM   #18
I also saw that you have a mic preamp with a compressor (separate schematic) and wowow! Have you actually tried using it? Can you describe how it sounds? Seems that all the parts are locally available here except for the LED/LDR part. Maybe I can just build a discrete LDR/LED for such use?`
perhaps the WHAT-compressor?
Old 10th September 2004, 11:04 AM   #19
JojoD818's Avatar
Geek's tube mic preamp is here: http://www3.telus.net/small_business...reampFINAL.png
and i i think this is the compressor: http://www3.telus.net/small_business...ssorDriver.gif
Note: This is from Geek's circuit collection...
Old 10th September 2004, 11:06 AM   #20
did'nt you see my question?
it's according to this preamp!
12AX7 sound ... going with the trendHide this!Advertise here!
12ax7 nigelwright7557 Tubes / Valves 6 1st June 2008 02:54 PM
Trend Audio or Sonic Amp just "sitting" around?? JeremyB Swap Meet 0 13th December 2007 02:53 PM
Diy Speakers for Mardis Trend 10.1 Shiznit Multi-Way 0 12th June 2007 01:13 PM
Balanced amplifier trend? LBHajdu Pass Labs 12 29th September 2005 02:32 AM
12ax7 Matthewong Tubes / Valves 0 12th June 2005 04:54 PM
Copyright ©1999-2017 diyAudio
