variable regulated negitive grid supply
Old 3rd September 2004, 12:32 PM   #1
Svetlana is offline Svetlana  New Zealand
Question variable regulated negitive grid supply
I want to parell output tubes, in a PP amp.
All the tubes draw different ammounts of plate current for the same given negitive grid voltage.
So should I devise a variable regulated negitive grid supply for each tube, then adjust to set all of the tubes to draw the same plate current?
Old 3rd September 2004, 11:36 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
If you put in matched tubes the currentdraw should be shared more or less equally among all of them.
A few mA difference won't matter much for as long as they stay within that range after burn-in.
Going for individual bias on every single one is a possibility but certainly not economical and in almost all cases absolutely unnecessary.
Frank
Old 4th September 2004, 12:09 AM   #3
Hi Frank,
I wish they were matched.
The current range is from 60ma to 415ma at the same given negitive grid supply.
Old 4th September 2004, 12:21 AM   #4
fdegrove's Avatar
?? Are you sure about this?
What are these tubes BTW?
Frank
Old 4th September 2004, 12:35 AM   #5
old 6v6's
Old 4th September 2004, 12:48 AM   #6
fdegrove's Avatar
old 6v6's
Under no circumstances should you have more than 45mA idling current per tube.
You must be doing something wrong there...
Frank
Old 4th September 2004, 06:21 PM   #7
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
If the +B is unregulated, it's best IMO to leave the grid bias supply unregulated.
The reasoning is thus:
If the valves are running anywhere near max dissapation, ann increase in mains voltage could cause them to overrun. However if the grid bias is unregulated, this will tend to compensate, and the valves will be safe.
Of course you still need the supply to be low impedance.
variable regulated negitive grid supplyHide this!Advertise here!
Variable AC Power Supply Rino odorico Everything Else 12 14th March 2013 04:56 AM
3 Pin regulated supply VS zener based supply KevinLee Solid State 3 15th September 2008 02:40 PM
UK: Variable voltage regulated PSU's ShinOBIWAN Swap Meet 0 15th May 2006 07:31 PM
UK: Built & Tested ESP P101's, Variable Regulated PSU's, Lots of Hitachi L-FETs ShinOBIWAN Swap Meet 3 21st July 2005 10:53 PM
Digital Variable Power Supply jleaman Digital Source 13 13th April 2004 10:09 PM
