| diyAudio Sponsor | ||
About a year ago, I installed a quad set of Electro-Harmonix 7591EH tubes in my old and fully restored HH Scott model 299C amplifier. The tubes have performed beautifully ... sonically they have been better than the original 7591A tubes.
A couple of days ago, I noticed a slight 120 Hz hum coming from the right channel speaker so, using the instructions provided by HH Scott back in 1962, I removed the 6U8 driver and adjusted the bias balance pot for minimum hum. I was able to reduce the hum somewhat when the pot was at the end of its travel. I replaced one of the output tubes with an original 7591A and was able to null out the hum. I'm not sure what has happened to the 7591EH but I will build a test jig so that I can compare the bad tube with a good one. Has anyone else in the Forum experienced a similar failure with the 7591EH tubes?
Frank |
#2 |
I don't have any experience with Electro-Harmonix 7591 tubes, but this looks like heater-cathode leakage or short. The tube could suffer from it due to less quality of the materials used inside your tube.
Also make sure you don't exceed the maximum heater-cathode voltage by connecting the heaters to a reference point. BTW, I love Florida, was there 3 weeks ago. Dick
Music is the best F.Z. |
#3 |
Dick,
Thanks for your quick reply. Florida is hot and humid today. The cathodes in the 299C are at ground potential and the filaments are floating with a balance pot to ground. The tubes are operating well within their specs. It appears that the 7591EH was continuing to operate ... but with far different specs. I really didn't notice an increase in the distortion nor did I notice a reduction in output power. Tests will confirm the failure mode.
Frank |
#4 |
I had one of a quad of fairly new EH 7591 exhibit the same problem - loud hum from the speaker but the tube carried on working. It did test weak, but also seemed to go up and down a bit. Couldn't find any reason why that particular tube gave out - it was not driven hard at all. Edicron in the UK, who supplied me, replaced it immediately with one day turnaround - I couldn't ask for better service. Don't know if this is a coincidence or whether there's some potential weakness.
#5 |
andyjevans,
Thanks for your input. One thing I just remembered. The amplifier is in my office and operates about 8 hours per day. Last week, I noticed a noise when I turned the amp off. I had never noticed the noise before. I heard a "tink, tink, tink" as tubes cooled down. Perhaps the noise was coming from the bad tube. A broken internal support?
Frank |
#6 | |
diyAudio Senior Member
Unless the tube was glowing cherry red, I'd say that pretty normal behaviour. Cheers,
Frank |
#7 |
Thanks for your input, Frank.
I hear the same thing on my power amplifier at home. I just never noticed it from the one at work. New tubes are on the way. Until then, I'll use the old 7591A tubes and enjoy the music.
Frank |
#8 |
Hi Frank,
I've used many Electroharmonix tubes in several amps. I have been very happy with them. I have run into a bad tube also, but that is to be expected. When I'm finished rebuilding my Eico ST-70, I will use Electroharmonix again. -Chris |
#9 |
Chris,
I trust them too. I've ordered a replacement pair.
Frank |
#10 |
I should add that the EH 7591s themselves sound great - very detailed and punchy. Very useful valve, because it's so easy to drive - I'm driving with a 6C5G DC coupled into a 12B4 concertina. Using it UL without feedback into 6.6K
| Krell KSA-250 failure | highend-madness | Solid State | 19 | 8th September 2007 11:06 PM |
| Bass Amp Failure | BOCHIN | Solid State | 6 | 3rd April 2005 12:59 PM |
| Amp failure .. . | DilutedImage | Car Audio | 11 | 23rd August 2004 08:40 PM |
| JBL PB12 Amp Failure | Galen | Multi-Way | 3 | 28th November 2001 08:01 PM |
| Page generated in 0.10882 seconds (77.30% PHP - 22.70% MySQL) with 10 queries |
