My ForePlay Processor Controlled Preamp - Page 4 - diyAudio
Old 5th December 2004, 08:45 PM   #31
Algar_emi's Avatar
I just added two PI filters on the filament supply of each tube. The filament supply was 6.7V and a bit too noisy at almost 300mV of ripple
So I added a 0.2 ohm resistor (nice power resistor that I had in stock) and a big 10,000uf cap for each tube. The voltage at the tube drops to a nice 6.3V and 60mv of ripple, much better
Old 10th December 2004, 02:55 AM   #32
Algar_emi's Avatar
Listening Session
My first lsitening was very interesting. The high were sweet and the bass was good too, but the medium had some coloration to it, in particular female voices. I was using a sole AuriCap coupling cap at the preamp output.
There was also the noise issue. There was two problems. I could here a rather loud buzz noise when activating the volume motor control. There was also a hiss sound in the background that reduce the dynamic of music.
I solved the two noise problems at the same time. I ground the case of the potentiometer/pot to the chassis ground. The hiss is just gone and the motor buzz can be eared only at high volume. I can live with that, no problem.
Then I installed the NOS Sprague coupling Caps instead of the AuriCap I had (Thanks Robert) and I can just say WOW!!!
The sound now is just great. Any coloration on voices is gone. The sound is just pure and liquid. The music timing just sing.
I couldn't believe the sound that can have just one cap. This NOS Sprague cap just blow the AuriCap to the sky
I listen to it all evening. Patricia Barber in SACD is cool. Return to Forever-Romantic Warrior punch and rock. Greats recordings just stand out. Chris Botti-Night Sessions is liquid and sexy.
Ayreon-Human equation bring down the house. My Naim CD Sampler with great acoustic recordings lovely. Steely Dan-Two Against Nature rocks, what a great pop reording. Diana Krall-Live in Paris swings. Gary Willis-No sweat, what a great bass player.
The voices are clear and well defined. Small details everywhere. It really sings.
Real music. This is the best preamp I ever built. I can wait to install CSS option and see what changes it will bring, for the better I hope
Bye...
Old 11th December 2004, 01:31 AM   #33
Algar_emi's Avatar
Here the complete circuit finished. Check the nice NOS Sprague coupling caps
Old 11th December 2004, 06:49 PM   #34
Algar_emi's Avatar
I did some measurements. Here the Unofficial Specs
Vin Max: 1.4Vrms
Vout Max: 14.6Vrms
Gain Voltage: 10 or 20dB
Zout: 600 ohms
BandWidth (-3dB, ref. 1Khz, 1V): 2Hz - 70Khz
Distorsion (in 10Kohms, 1V): 0.40% (1Khz), 0.38% (20Khz)
Noise (Input gnd): 0.2mv (min. Volume), 0.8mv (max. Vol.),
Crosstalk:
-between input channels (Ref 1V): -78dB (1Khz), -65dB (20Khz)
-between output channels: <70dB (noise floor, 1Khz), -62dB (20Khz)
Very good indeed
Old 14th December 2005, 05:38 PM   #35
Algar_emi's Avatar
Distorsion is probably lower than that because it seems that my distorsion analyzer got a problem. I need to re-test it using my Clio system. More on that later...
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 09:08 AM
Foreplay Preamp volume popping arc2v Tubes / Valves 7 22nd August 2007 03:04 AM
Preamp: Foreplay or 5687 or 12B4 Toyman_PA Tubes / Valves 24 4th August 2004 04:10 PM
Pics of Foreplay Preamp TubeHound Tubes / Valves 16 5th February 2003 01:29 PM
Tube preamp similar to Foreplay JAZZ2250 Tubes / Valves 6 10th December 2002 10:14 PM
Copyright 1999-2017 diyAudio
