My ForePlay Processor Controlled Preamp - Page 3 - diyAudio
Old 13th October 2004, 04:06 AM   #21
ALBQ is offline ALBQ  United States
Default Check in
Algar,
Long time since I hear anything. Hope project is progressing. A quick question, have you tested your control circuit yet? Know you added a couple switches to the code I wrote and curious to know how its going.
Take care, ALBQ
Old 13th October 2004, 11:08 AM   #22
Taco is offline Taco  Netherlands
Very nice project, I missed your initial post ... I like your chasis .
Old 29th November 2004, 02:21 AM   #23
Algar_emi's Avatar
Hi everyone. I've working on that project part time. It is almost done now.
The switches are well integrated in the code. The code is almost completed. I'm still working to improve the volume motor control. I what a smooth, continuous operation. I'll post the code when completed.
I completed the analog assembly. Here the power distribution with the small control supply transformer. At the AC input there is an EMI filter with fuse integrated. The main supply goes to the main power switch and the control transformer. Then 2 relays control the filaments and HV in sequence at power up and power down.
Old 29th November 2004, 02:25 AM   #24
Algar_emi's Avatar
GND is very important. Here the safety GND point. Directly connected to AC earth gnd it connect to both top and bottom metal covers. It connects also to the rear AC plate on a screw marked GND. Then it goes to a small junction point throught a gnd loop breaker, 10R, 3W resistor and a 0.1uF, 400V, X2 type in parallel.
Old 29th November 2004, 02:30 AM   #25
Algar_emi's Avatar
Then all the GND inside the preamp connect at one point only, the star gnd on the left. This this point connects directly to earth gnd throught the GND loop breaker. The GND are all run separately:
HV and Filament supplies power GND, right and left audio channels, audio gnd of the jacks on the back.
That note that the digital gnd is not connected anywhere to the preamp gnd. The digital section runs on a completly separate supply.
File Type: jpg star gnd connected to safety gnd_small.jpg (67.4 KB, 672 views)
Old 29th November 2004, 02:34 AM   #26
Algar_emi's Avatar
Both supplies use MUR860 soft recovery diodes with caps snubber. I used WIMA MKP small caps on the filament and X2 HV type on the HV section. Everything is point to point. I'm using lacque coated good grade copper wire. This wire is the same used to rewire motor for greater efficiency. It is hi conductance copper from a electric motor shop.
The filament rectifier bridge is on the front, the HV is on the back. The power transformer sits just under the bridges.
Old 29th November 2004, 02:37 AM   #27
Algar_emi's Avatar
This is the HV filter section. I'm using a three section PI filter, with 330uF, 400V and 1K resistors. A 120K bleed resistor is at the end with a ERO KP1832 bypass cap that I had in stock (check on the left). Check my "wood vibration absorber' for the caps
The nice power resistors are from a surplus store. Not needed but nice
Old 29th November 2004, 02:40 AM   #28
Algar_emi's Avatar
The filament filter with the two 3300uF caps well mounted on the metal frame. I added an ERO MKC1863 1.5Uf as bypass cap.
The power transfo used Hammond 269AX, can provide enough current to supply 6N1P tubes, 6.3V, 2A
You can also see the base of the releays mounting plate.
Old 29th November 2004, 02:48 AM   #29
Algar_emi's Avatar
This is a complete channel. Missing are the wires from the volume pot and the output coupling cap. I will use a NOS paper in oil from Sprague. I'll do some listening, and I may use a bypass with an ERO KP1832 cap.
Check the power distribution with the nice wires, gnd, filament and HV supply. I used massive bypass on the 470uF, Panasonic decoupling cap on the cathode resistor. Electrolytic cap at this location are reported to add to the sound. The bypass are a try to improve on that, Still need to listen to it. I used what I had in stock, 2.5uF Cornell Dubiller poly cap and 0.047uF ERO KP1832.
Check on the left of the socket.
I also added ferrites on the filament wire to reduce radio induction if possible, check the two small beads on the wire.
That is all for now.
Old 5th December 2004, 08:37 PM   #30
Algar_emi's Avatar
Here, I just completed the front panel.
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 09:08 AM
Foreplay Preamp volume popping arc2v Tubes / Valves 7 22nd August 2007 03:04 AM
Preamp: Foreplay or 5687 or 12B4 Toyman_PA Tubes / Valves 24 4th August 2004 04:10 PM
Pics of Foreplay Preamp TubeHound Tubes / Valves 16 5th February 2003 01:29 PM
Tube preamp similar to Foreplay JAZZ2250 Tubes / Valves 6 10th December 2002 10:14 PM
Copyright 1999-2017 diyAudio
