My ForePlay Processor Controlled Preamp
Old 28th August 2004, 03:25 AM   #1
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Default My ForePlay Processor Controlled Preamp
I started my new project to go with my Peter Daniel's Gain clone. The GC is great, but I want some more flexibility with inputs selection, Remote control and a little bit of nice, warm tube touch.
This project is also my first complete Processor controlled preamp. After searching I decided on the BottleHead ForePlay preamp. It use basicly the same topology but uses DC filament.
ALBQ, an other member of this great forum was of great help on this project. See his excellent website on his own preamp at:
http://mywebpages.comcast.net/gilles...U7-Preamp.html
I also decided to implement right away most of the mods that I found on the ForePlay.
The Features list is:
Frame:
Nice Oak tainted Red Mahogany by MinWax excellent product.
Top and bottom Plates are steel, 1/8 thichness, that I salvaged from a 19" rack shelf (very strong)
DIY Volume knob and Function buttons made of aluminium
Vibration Control:
Vibration absorbant sheet glued on top & bottom plates.
Rigid steel sub chassis to hold inside parts.
Transformers mounted on rubber bushing.
Arrowhead used as decoupling points.
Wood Capacitors Bracket holder, you'll will see.
Nitrile o-rings on Tubes
Circuit:
Processor Controlled with IR Sony compatible remote control
LCD Display with BackLight.
Serial port to change BasicStamp Program externally.
4 Inputs, 1 REC Output, 1 Output
Motorized ALPS Volume Control
Completly separate Control Power Supply with noise filtering
Front Panel Function buttons: ON/Standby, Channel Selection, Mute
Power Up and Down sequence to protect tube
Automatic 45-sec. warmup mute. Automatic brown-out mute.
Main Power switch with On steady / Flash Standby Led
IEC-standard three-pin socket at the rear, allowing custom A.C. cords to be used. Includes an integrated noise filter.
Extensive GND layout with Power, Audio and Control GND united at a Star Gnd.
Safety GND and RC GND Loop Breaker.
Mods
Camille Cascode Constant Current Source upgrade
Parts Upgrade
Relays Input selection and Mute. COTO Sealed relays with eletrostatic shield to reduce crosstalk.
RCA gold Plated connectors.
Magnet Wire GND wire
Teflon coated high purity copper wire
Bigger Hammond HV, filament transformer. So I can use different tube
Azuma 9 pins Gold-Ceramic socket
Dale RN60D Film Resistor for small signal and Xicon Power Carbon Film Resistors
Panasonic TS-Type 105C capacitors in Power supplies.
Panasonic FC-Type decoupling caps.
Wima MKP bypass caps.
ElectroCube Film coupling cap.
Fast Recovery Diode with snubber for filament and HV supplies.
DIY AC Power Cord with Hubell connectors
Old 28th August 2004, 03:30 AM   #2
Algar_emi's Avatar
Default First, the wood frame
The frame is made of oak. I cutted all the holes first. Used a router to cut in the front panel to let place for the LCD display, Switches PCB and motorized pot. Four nice coats of Red Mahogany Red MinWax Vernish/Taint covering. Here it is, not too bad.
Old 28th August 2004, 03:32 AM   #3
Algar_emi's Avatar
And the back
Old 28th August 2004, 03:39 AM   #4
Algar_emi's Avatar
Now, I started the mechanics. Two aluminium plates are on the back. The first one is the RCA I/O plate. The RCA GND doesn't touch the frame so the audio gnd can be run separatly up to the star GND.
Old 28th August 2004, 03:48 AM   #5
Algar_emi's Avatar
The other plate is what I called the AC Outlet plate. The IEC noise filter with integrated fuse socket is mounte there. It contains also the Processor serial port and the Frame GND screw. This screw is connected to the AC safety gnd. Two wires go from there and connect to the top and Bottom steel plates for safety.
Then it goes to an RC Gnd loop killer 10R,3W and 0.1uF, 400V, X2-Type cap.
Then the other point of the RC goes to the preamp star GND point. These GND are not directly conencted to the frame (safety gnd).
Old 28th August 2004, 03:54 AM   #6
Algar_emi's Avatar
Here all the work to machine the back of the front panel.
Old 28th August 2004, 03:59 AM   #7
Algar_emi's Avatar
Then I did own buttons for the front panel. They are made of 1/4 inch alu bar. Then I polished them. Square button will make a nice look!
Old 28th August 2004, 04:01 AM   #8
Algar_emi's Avatar
Now the volume knob. Not to massive so the small motor of the motorized pot stop working...
Old 28th August 2004, 04:05 AM   #9
Algar_emi's Avatar
Here the complete prototype of the front panel. I found a very nice metal window for the LCD display and IR receiver. The Plexiglass window will be orange with red filter insert for the IR Receiver.
Old 28th August 2004, 05:47 AM   #10
Algar_emi's Avatar
Inside, i needed to hold the tube supplies caps in place. I also need to find a place for the relay assy. These relays turn on the filament power, then the HV in sequence under processor control.
I also wanted to keep the AC on the right (view from the bottom) and near the AC outlet. I'll keep the audio on the left. The control will be on the right near the front.
Instead on drilling a lot of holes in the top plate, which is least nice, I salvaged a steel sub frame from an old computer monitor. I cut the frame according to my need and install it using just 3 screws on the top. Then I'll use this frame to mount the reast of the big stuff. This frame is also quite rigid.
My ForePlay Processor Controlled PreampHide this!Advertise here!
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 09:08 AM
Foreplay Preamp volume popping arc2v Tubes / Valves 7 22nd August 2007 03:04 AM
Preamp: Foreplay or 5687 or 12B4 Toyman_PA Tubes / Valves 24 4th August 2004 04:10 PM
Pics of Foreplay Preamp TubeHound Tubes / Valves 16 5th February 2003 01:29 PM
Tube preamp similar to Foreplay JAZZ2250 Tubes / Valves 6 10th December 2002 10:14 PM
Copyright ©1999-2017 diyAudio
