need 13fd7 curves
need 13fd7 curves
Old 23rd August 2004, 03:30 PM   #1
alejo is offline alejo  Argentina
Unhappy need 13fd7 curves
Hello, I interesting to buil a little SE amp around a disimilar triode 13fd7.
In Duncanamps page find datashet for this double triode but not find curves, I need this for desing.
The 6V version of this triode name is 6fd7.
Plese, if you now where I can find this.....
..thanks
Old 24th August 2004, 02:57 AM   #2
PrairiePete is offline PrairiePete  Canada
Default 13fd7
I think the closest you are going to get, is the 6em7. Triode 1 is identical. Judging by other circuits (6em7), run triode 2 as per the manual for a 6fd7. In this case 150v, -17.5v at 40ma.
http://www.pmillett.addr.com/tubedat...t%202/6EM7.PDF
Old 24th August 2004, 04:41 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Maybe this will help:
CROSS REFERENCES
I haven't checked if any of the references have a published datasheet showing curves.
Seeing what the tubes were designed for, I doubt any of them will.
I recall having had to plot the curves ourselves when trying to decide which of those disimilar triodes was best suited for a headphone amp....
Frank
Old 24th August 2004, 09:27 AM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Aaargh! I looked up that reference, Frank, and it had 6ES8 as a replcement for 6DJ8! Now we know where all that trouble started.
(For those of you who didn't know, 6ES8/ECC189 is a variable-mu double triode, whereas 6DJ8/ECC88 is constant, so if you try to use 6ES8/ECC189 for audio, you can count on increased distortion.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th August 2004, 09:15 PM   #5
fdegrove's Avatar
Oh dear...
I doubt they were the cause of the confusion. Many publicized documents list it as being a substitute anyway.
What caused the troubles is some greedy vendors rebranding their stock of ECC189s turning them into fake ECC88s IMO.
Either way, it's generally good practice to know that most so called substitutes will "work" in most circuits although far from optimally in quite a lot of cases.
For a finely tuned audio circuit it would be good practice to carefully check with the datasheets first.
Frank
Old 25th August 2004, 12:51 AM   #6
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
For what it's worth, the 6DE7 (10DE7, 13DE7) DOES have curves at Frank's place (though the smaller triode has lower gain), and it's pin-compatible with the 6FD7. So you could start with that one, and if you need the gain, drop in the 6FD7. They all are probably close to 6EM7 / 6FG7 / 6FM7 etc.
need 13fd7 curvesHide this!Advertise here!
PHL Curves - anybody have? Bill Fitzpatrick Multi-Way 3 30th November 2012 11:52 AM
DIY U-L curves Bandersnatch Tubes / Valves 10 1st August 2008 12:00 PM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 07:10 PM
Curves, curves, and more curves CarlyBoy Tubes / Valves 5 1st December 2006 11:11 AM
where's the curves? bostonswoop Multi-Way 13 13th March 2006 01:32 AM
Copyright ©1999-2017 diyAudio
