300B pp schematic found, what about it?
Old 24th August 2004, 10:05 PM   #21
jogas is offline jogas  Italy
attached you will find the "specs" I got from digitex.it
IN400 600 W 1 : 4 ct 15-30 KHz 150 H 10000 W
Trasf. traslatore di ingresso
linea bilanciata
Scatolino
resinato
L. 73.000
Of course they mean Ohm and not W, the price is still in Lire and is equivalent to 37 Euro.
BTW, this is not changing your judgment on the circuit I suppose...
Old 24th August 2004, 10:18 PM   #22
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Hmm, i'll be damned
Too much wine tonight. The diode is only to ensure the neon fires only at negative (positive may be normal operation) voltage
Old 24th August 2004, 11:51 PM   #23
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I don't think those neons care either way.
The diode could be for sequencing too, not sure.
Anyway, maybe this could be of interest:
NEONS GALLORE...
Frank
Old 25th August 2004, 01:08 AM   #24
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
Okay, so it's a 1:2+2 Phasesplitter, a not particular ideal choice I'd think, thus leading to requiring a 600 Ohm input (meaning one where the load is 600 Ohm). My guess, at the cost and with the size constraints they had trouble finding anything more suited. I may be wrong of course.
Not really. As said, in the context of the Amplifier modified the circuit is an improvement and generally a "good idea", but in absolutle terms the whole thing is still hamstrung.
BTW, the Kennedy Circuit discussed elsewhere, while having much to recommend it also is notably off from ideal in my view.
For a simple circuit I'd suggest an Allen Wright style cascode. If you want be thumping your nose at people you could even make it a hybrid cascode with J-Fets below a 6SN7 with another J-Fet as CCS. Then you could use a pair of Wright SLCF's also hybrid to drive the the grids of the 300B in fixed Bias mode for something like 40...50 Watt in Class AB2.
If you ask me, now we are cooking with an open range and charcoal (I know, supposedly Gas and later Microwaves where an improvement, yeah, sure).....
Sayonara
Old 28th August 2004, 02:15 AM   #25
rcdaniel is offline rcdaniel  Australia
Hi all
I hope this helps explain the circuit posted earlier by fdegrove.
http://www.svetlana.com/docs/TechBul...hnoteNo57.html
Cheers
Ray
300B pp schematic found, what about it?Hide this!Advertise here!
Hey...found the Acoustat TNT-200 schematic! (and TNP preamp) KBK Solid State 69 22nd June 2015 12:04 AM
Found this -well prepared- TDA1562Q 70watt amp. schematic.. deepanger Solid State 30 15th December 2010 05:23 AM
Found Meixing Amp schematic, sorta, would like some feedback pjpoes Tubes / Valves 3 4th March 2007 05:22 PM
Preamp Schematic I Found On The Web. Feed Back Wanted. LJOE1969 Instruments and Amps 5 29th August 2005 06:53 PM
just found back a quick drawn schematic of my amp hugobross Solid State 27 26th June 2003 12:29 PM
Copyright ©1999-2017 diyAudio
