Toroidals as OPTs? - Page 2 - diyAudio
Old 22nd August 2004, 07:53 PM   #11
smoking-amp's Avatar
Default bifilar primaries
"That's most surprising. I'd expect safety problems "
Yes, I agree. I was surprised to find it was wound that way too. Probably why it was being sold surplus. It was coated in epoxy so was not obvious until I tore it down. I mentioned it to someone in the power supply industry and they thought it was a poor idea too. Since then, however, I have been even more shocked to find that the low cost E-I dual bobbin transformers sold by the likes of Signal, Stancor, Magnetek ... etc all have their dual 120V primaries wound bifilar on one of the bobbins. These are most likely all made in China. I also had a Jameco low cost E-I isolation xfmr which buzzed and had high common mode capacitance, so I tore it down to see how it was made, and it had restamped laminations full of holes and cutouts with no insulation between primary and secondary. Probably from India. Apparently old scrap laminations are shipped over there and they punch out smaller lams from the pieces. Transformer quality is getting scary.
For that reason I have been accumulating some large toroid cores from the local scrap yard with the idea of re-winding them myself for audio outputs (bigger core, fewer turns). The secret of getting large bandwidth from toroids is actually well known and published, and far simpler than the interleaving complexities of E-I xfmrs. Each winding must be wound using progressive or chevron winding technique. This is done by dithering the core back and forth slightly as the winding is done in a single overall pass around the core (on automated equipment). The winding piles up in short chevron shaped layers with the result that all turns are always near turns with little voltage difference. This minimizes distributed capacitance. For DIY, can just use a lot of multi-layered 1/2 inch wide mini-sections with an insulating sheet between adjacent section ends. Good insulation between the overall windings (layered) (and core too) is needed to minimize common mode capacitance. By making each chevroned or mini-sectioned winding cover 95+% of the core, leakage inductance is minimized. The toroidal core with no lamination gaps allows one to use higher maximum flux density as well (10,000 G versus 7500 G ,M6, for E-I) for higher power rating (with same linearity) and has higher effective permiability for higher primary shunt inductance. You can expect to get near 1/2 MHz bandwidth this way.
Don
Old 22nd August 2004, 10:21 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
A very interesting post - although hugely alarming. I may have to investigate some of my transformers...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd August 2004, 11:40 AM   #13
hacknet is offline hacknet  Singapore
Default Re: Re: Re: Re: commercial power toroids
Originally posted by EC8010
Who knows? A toroidal main transformer will certainly be cheaper than an output transformer designed for the job. I suspect in the end that it will be down to whether you can keep those anode currents in balance. If you can, then the HF performance will probably be better.
well, toroidals arn`t particularly cheap.
are they implimentable in SE?
Old 23rd August 2004, 08:27 PM   #14
diyAudio Senior Member
fdegrove's Avatar
They could be provided you make sure there isn't any DC flowing through them....as in a parafeed design for instance.
Frank
Old 24th August 2004, 04:11 AM   #15
jlsem is offline jlsem  United States
jlsem's Avatar
Or just use a gapped toroid. They are available, believe it or not. I'm guessing Plitron uses them in their single-ended line.
John
Old 24th August 2004, 11:34 AM   #16
gapped toroid? wheres the gap?
Old 24th August 2004, 11:46 AM   #17
Steve Bench has used a small powersupply Toroid as an output
transformes in one of his many unusual amps. Sorry I didn`t book
mark that page.
Woody
Old 24th August 2004, 12:50 PM   #18
jackinnj's Avatar
John
If you read the links to Sanjay Maniktala's web presentation which I mention above (the notes are in a PDF file) you will find the gap equations. Do you expect your mother to do your homework?
Old 24th August 2004, 12:55 PM   #19
garbage is offline garbage  Singapore
garbage's Avatar
mark that page.
Woody
Steve Bench's page
Old 24th August 2004, 12:59 PM   #20
the notes din`t really make sense since i have no formal ee education
toroidals Professor smith Swap Meet 0 30th November 2008 10:50 PM
Toroidals for LM3875 Nordic Chip Amps 12 20th September 2005 05:53 PM
Dual Toroidals???? bowdown Solid State 3 31st December 2004 09:25 AM
0-42 0-42, 1500VA Toroidals richie00boy Group Buys 10 23rd November 2004 11:24 PM
Copyright 1999-2017 diyAudio
