Anyone know what this is?? Strange tube/ bulb. - Page 2 - diyAudio
Old 18th August 2004, 01:09 PM   #11
Magura is offline Magura  Denmark
Magura's Avatar
Maybe this info should have been included in the first place.
If you look at the first photo, you will see the dessignation in russian...the first 3 letters that is. I cant type those russian letters so youll have to look at the photo. after the 3 letters it says "-51". Does that help any?
The tube is brand new, one side is metallized for the sake of reflection (I believe), the other side is clear.
Cheers
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 18th August 2004, 05:03 PM   #12
One pin of this tube is connected to that metallic side and the other pin is not connected and just stays in the middle of the tube? If yes, then this tube is photo sensor - try to light at it and measure the voltage on the pins.
Old 18th August 2004, 05:16 PM   #13
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Originally posted by rcavictim
Does an ohm meter show any continuity between the end pins? My initial reaction is that this is a small short arc lamp which would show no continuity. If that is the case a rather specialized power supply is needed to light it. It seems very dark. Unless that is a special filter coating the bulb has long use on it.
Ah, another good suggestion.
Nothing too specialized, you could test with a neon sign transformer and see what it does. For full operation you may need a current-limited 800VAC (OCV) power supply capable of oh... 20-50 amperes.
Xenon would glow whitish. Do not run for more than a couple of seconds.
Yes, interesting things happen when glass is in direct contact with pure plasma at 20,000°F+...
I'd advise against "just plugging it into the 120 volt mains" in case it is a low voltage filament lamp. That will instantly ruin it.
True. Good reason to use a variac and maybe transformer.
Do you collect interesting vacuum tubes as a hobby? I do.
I do, although I don't have a habit of seeking them out...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 20th August 2004, 04:37 AM   #14
Magura's Avatar
Ive found out that its a photo sensor.
It gives 55mV at regular room light intensity.
Thanks everybody!!!
Magura
Old 20th August 2004, 06:49 AM   #15
rcavictim's Avatar
Default Valve/tube collecting
Tim
Tim,
That Raytheon tube you showed looks like a waveguide mounted TR switch for microwave radar. I could not find it in TubeLore however. My second guess if that was wrong is a klystron for a laboratory microwave signal generator.
I collect interesting tubes and valves but probably as you, not by seeking them out. I just hold on to them as I acquire them and in all my years didn't throw many tubes away. Those that I did I am frightfully sorry for now. I used to have quite a collection of interesting small CRT's now long gone but my collection has come back in those a bit since my last move 7 years ago. I wouldn't consider myself a tube collector really. I have a bunch of the more interesting looking ones in a glass display case in my home as technological curiosities mostly. Vintage TV sets with round picture tubes....now for those I consider myself a collector! Much deliberate searching, travel and expense to purposefully drag a large quantity of those across the border and eventually home, although I haven't bought one in several years now due to having run out of space in which to display them.
Rob
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 20th August 2004, 08:14 AM   #16
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Magura...
those things had a special name for them...?? Haven't seen one for ages!
Was it Cadmium Sulphide for the active element?
Strange though, -- the heavy terminals somehow indicated a large current device....always somehting new to be learned.......!
EDIT:
Just googled up this one, - my internal memeory isn't that bad afterall
http://www.phanderson.com/printer/cadmium/cadmium.html
Old 20th August 2004, 09:31 PM   #17
Sch3mat1c's Avatar
Default Re: Valve/tube collecting
Yep, klystron. I forget what frequency (1-2GHz?) but it's in the mW range. I think TDSL has something on it. ... Yep, two from the Valve Museum and one from WPS. 1.5-3.75GHz, 140mW max.
I've wondered if I could use it as an esoteric tetrode instead.
P.S. I've got a cute viewfinder CRT... 1" diagonal..
Tim
strange tube gianis33 Tubes / Valves 19 26th January 2009 01:23 AM
strange tube adalin Tubes / Valves 5 28th August 2007 10:52 PM
strange tube G1 S/5 Mr. Triatic Tubes / Valves 22 6th June 2006 11:42 AM
strange tube gianis Tubes / Valves 10 7th March 2005 11:42 PM
Strange Tube adalin Tubes / Valves 11 14th July 2004 08:30 AM
Copyright 1999-2017 diyAudio
