Old 13th August 2004, 09:19 PM   #1
MrTransistorm's Avatar
Default JJ multisection caps
I'm going to be building a few preamps. I have been using Mallory CGS for my full amps, but I need conserve space in the preamps. Has anyone used JJ? Any other recommendations (besides Black Gate$)? I'd like to stick with current production caps in case I start making more preamps.
One preamp design will be an RIAA pre only with two 5751's and one 12BH7. The other design will include the RIAA section plus a 12B4 line stage. Both preamp designs will use the same power transformer and CLC filter. RC filters will be used to achieve the desired voltage in each stage. No regulation except DC for heaters.
Thanks.
Dave//
Old 13th August 2004, 11:32 PM   #2
diyAudio Senior Member
fdegrove's Avatar
The JJ caps are excellent, better than your average electrolytic cap by no small margin.
Other excellent electrolytics are being made by Philips and Siemens/Epcos. I don't recall the exact reference but check for their very low ESR types.
Other than electrolytics, which I'd recommend only in case large capacitance values are needed, there are of course various makes of MKV and MKP caps.
All of which should easily outperform any electrolytic caps. Most common brand in large values for MKP caps are Solen Chatreauroux.
For MKV nothing beats the Epcos to my ears even as coupling caps these are extremely good sounding.
Frank
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 10:17 PM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Silver Mica caps VS Polystyrene caps KevinLee Parts 24 17th September 2003 03:01 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Multisection Can Caps Vs. Individual Electrolytics DocJDG Tubes / Valves 4 14th January 2002 12:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
