Trying to find an amp - diyAudio
Old 13th August 2004, 05:03 AM   #1
lawbadman's Avatar
Default Trying to find an amp
Hello,
I just bought a Heathkit IP-17 power supply, its output is 0-400VDC at 100mA, 125mA max. The schematic is here: http://www.mcmlv.org/Archive/TestEquipment/IP17.pdf
Can anyone suggest a good tube amplifier to go with this power supply?
I was thinking about the amp below, is it OK?
Old 13th August 2004, 11:35 PM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
This schematic will be drawing about 80mA per channel, a bit much for your power supply. Assuming you are building a stereo amp, I wouldn't go above 110mA total...
However have you considered a stereo SET amp, say a 6B4G or 2A3?
Know where I might find this sub? Dominick22 Subwoofers 1 16th August 2006 08:39 PM
Where can I find this Pot US? jealousblues Parts 0 20th July 2006 04:08 PM
Help me find a job lawbadman Everything Else 28 14th June 2006 12:30 PM
$1 AMP find dougv Tubes / Valves 32 6th June 2004 08:03 PM
please tell me where to find kaukasion Solid State 3 3rd July 2003 09:58 AM
Copyright 1999-2017 diyAudio
