12v tube output stage for cs43122 based dac?
I am building a dac for use in a 12v enviornment. I am using the cdb43122 board schematic for reference, but would like to replace the opamps with an analog tube section. Does anyone know of a 12v stage that i could incorporate into the design? I also require a 12v remotely controlled analog volume control balanced in balanced out. I was wondering if something like the musical fidelity "missing link" style buffer would work since it was designed to work with 12v.
Thanks Hans |
Are you just interested in a tube buffer, or do you also care about preserving the analog low-pass filter? Would you be willing to switch to a passive (e.g. transformer-based) filter?
Re: 12v tube output stage for cs43122 based dac?
Konnichiwa,
Secondly, that thing was run from 12V AC which where put onto Voltage doublers, giving actually a 48V supply, so no, it was not designed to work with 12V. Sayonara |
Thank you very much for your input. Unfortunately i am not much of an electrical engineer. I can follow a schematic very well, but anything over a simple ciruit, i really cant design on my own. I do like the idea of using a dc-dc converter. Can you point me in the direction of a project that i can adapt to my one. I can combine several onto the same pcb. I aggree with not using an ic. I want a completly analog everything post dac. I want to eliminate the opamps, and use something like a motorized pot. I have 2 12v tube based balanced 3 way active crossovers that i will be using, and also 12v balanced hybrid tube amps. Looking for the ultimate organic sound in a car envoirnment without loosing any resolution.
Thanks Hans |
Konnichiwa,
DC-DC Converters are easy and if you need to, you can stack them to any more or less sensible voltage. Quote:
I'd probably suggest using a shunt attenuator and a suitable linestage with valves and a the HT generated with DC-DC converters. Look up the differential circuits by Allen Wright. Getting 144V +B (2pcs 72V DC-DC converters daisychained) would be likely enough to operate them, the DC offset from the DAC would give enough bias to stack the differential amplifier directly onto a J-Fet. Sayonara |
If by project you mean one using a DC-DC converter, you will find that they are rare in print and even more so on the web, especially if you are after one using encapsulated black box converters. There was one in Glass Audio around '89/90 using an encapsulated DC-DC converter generating 250Volts for a portable valve mixer. Around the same time in Audio Amateur there was a discrete DC-DC converter design for a car amp. And that about covers the last three decades, though there may be other projects out there. Your best bet for information on encapsulated DC-DC converters would be to visit the manufacter websites. http://www.cdpowerelectronics.com/ http://www.tracopower.com/ |
http://www.tubecad.com/january2001/page10.html
12VDC to 72VDC converter. You can get them at Mouser for $15 a piece. |
Steve Bench has a number of DC-DC converter PSU projects intended for tube service on his home page. Never tried any of them though.
Once you have the +72VDC of B+ using the DC converter, or 144 if you uses two, all you need is a cathode grounded design. Just follow the calculation below and you should be fine.
http://www.tubecad.com/articles_2003..._Amplifier.pdf For balanced to SE, try the Broskie Cathode Follower http://www.tubecad.com/october99/page9.html |
Konnichiwa,
http://www.tubecad.com/january2001/page9.html Here the salient point, how to make 12V into 84V: http://www.tubecad.com/january2001/img35.gif The converter is the Newport Components NMT1272SZ, costs around 15 Bucks and is good for 42mA. If you stack two you can get 156C and use a differential version of pretty much any classic Voltage Amp & Cathode Follower Something like this should answer the purpose.: http://img58.exs.cx/img58/7461/12VBalancedLine.gif The volume control Pot needs to be logarithmic. The high value series resistors pad down the DAC's output as the Linestage has a bit like way too much gain. There are other ways and options, like using just one ECC88 with +84V & -72V as buffers after the volume control, I hope this gives you some ideas. Sayonara |
| All times are GMT. The time now is 02:52 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
