cmrr of common cathode
Old 14th August 2004, 05:59 AM   #11
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Ya, in other words, CMRR doesn't apply here, but if you must, it's anti-rejected by the nature of the circuit. Hence = -gain............
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 14th August 2004, 11:10 AM   #12
Guido Tent is offline Guido Tent  Netherlands
Originally posted by runeight
I have noticed an occasional confusion in terminology for some tube topologies. i'm not saying which is necessarily correct, but maybe that's the problem here.
i think the original question is for a "common cathode" topology. i have seen the term "common cathode" applied to what I would call a "grounded cathode", the latter being the typical gain stage with an Rk and a Ck. this guy has only a PSRR.
a "common cathode" to me is two devices with their cathodes connected together, and separate plate and grid connections. which, if both inputs are used, is a differential amplifier with CMRR and PSRR.
if only one input is used and the other grounded, then this configuration is sometimes a phase splitter or just a non-inverting amplifier. the topology has no CMRR, but it has PSRR
if one grid is used for the input and the other for NFB, then the CMRR is what gives the NFB.
don't know if this has been the confusion, just a thought.
Hi
Nice discussion
Common in "my" terminology stems from the fact that input and output have the cathode in common, which is what runeight calls grounded cathode.
Such a stage does not have CMRR but ofcourse has PSRR.
Any stage with (intended) differential inputs has CMRR as well as PSRR.
Now back to the grounded cathode:
One may argue that such a stage has CMRR because the cathode and the grid both can be considered as "differential" inputs though most of the times one of the inputs is "fixed".
cheers
Guido Tent
www.Tentlabs.com
Old 14th August 2004, 12:47 PM   #13
runeight is offline runeight  United States
Yep, forgot about this one. And when the cathode is used for NFB (as in the input stage of so many power amp designs) it is the CMRR that provides the NFB.
Old 14th August 2004, 03:39 PM   #14
Not completely correct
CMRR is the suppresion of common mode signals to a differential mode output.
The principle of feedback applied to the cathode is that the effective anode current modulation is the result of the difference between grid and cathode voltage, and gm
best regards
Guido Tent
www.Tentlabs.com
Old 21st August 2004, 07:25 PM   #15
Yes, I see what you're saying, but I think your comment above is correct enough under most circumstances.
That is, if the plate to cathode voltage is very large compared to the AC signal applied to the cathode, then the affect of changing the cathode voltage on the operating point because the plate voltage is changing is generally a second order effect. If this is so, then to first order applying a signal to the cathode is the same as applying a signal to the grid with the inverse effect and so the grid-cathode form a sufficient differential input for CMRR to be relevant.
No?
cmrr of common cathodeHide this!Advertise here!
Mu-follower vs common cathode w/- active load jnb Tubes / Valves 7 24th June 2007 09:53 AM
Any common cathode (grounded grid) schematics? leadbelly Tubes / Valves 2 24th February 2006 07:29 AM
Common Cathode Resistor D0Hbert Tubes / Valves 1 4th March 2005 11:42 AM
Help with common-cathode circuit. JoeBob Tubes / Valves 48 1st March 2003 10:57 PM
hybrid common cathode amplifier? mwmitchell Tubes / Valves 19 16th January 2003 01:51 PM
